Go to Post There has to be a point where you go "I do not agree, but I can understand why they did it." - Lil' Lavery [more]
Unread 27-05-2011, 21:12
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: Alternatives to Welding?
Alternatively, you can use the joints found here: http://www.brunnerent.com/Tools/Port...d/itemlist.asp, but I can't vouch for them (I've only heard of them; our team has never actually used them).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 27-05-2011, 22:10
randomunchies's Avatar
randomunchies randomunchies is offline
Underling
AKA: Kat L
FRC #1261 (Robolions)
Team Role: Student
randomunchies is an unknown quantity at this point
Would those bend a lot easier than gussets?
Unread 30-05-2011, 21:40
DonRotolo's Avatar
Back to humble
FRC #0832
He is of course referring to the "Tubing connectors" shown on that page.
These connectors may be weaker than gusset plates; they will most certainly be heavier. If you used these connectors AND gusset plates, the joints will be nearly indestructible.
Unread 30-05-2011, 21:51
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
Originally Posted by randomunchies View Post
My team is seriously considering making the change from 8020 to tubing for next season. <snip>
-Kat
If your main concern with 8020 is the weight, just keep in mind that 8020 is pretty ridiculously as a cross member shape. Also, avoid using brackets if at all possible. Take advantage of end fasteners and anchor fasteners to save weight. Over the past few years of dealing with 8020 I have found that unlike a tubular chassis you need very little cross support to have a sturdy frame, pretty much an outer box is strong enough to hold.
If you have any more questions about lighter 8020 construction techniques feel free to respond/PM/IM etc.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 01-06-2011, 10:11
Dick Linn's Avatar
no team (Synergy)
If I were going to braze Aluminum, I'd probably go with something like Harris Cor-Al rather than stuff like muggyweld. This is an Aluminum/Magnesium/Silicon alloy, not full of Zinc.
http://www.harrisproductsgroup.com/e...um/Cor-Al.aspx
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-06-2011, 14:18
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
222 has used the 80/20 quick frame and connectors. Typically we would use gussets along with the corner connector in high stress areas. We have never had a quick frame connector fail on us.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 01-06-2011, 15:58
Dick Linn's Avatar
no team (Synergy)
Good old 1" square, 1/8" wall Aluminum extruded tubing is cheap and durable. Welded or put together with gusset plates and either rivets or #10 cap screws, it's workable.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 01-06-2011, 21:37
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
The Lotus Elise uses a glued and riveted aluminum extrusion chassis. I don't understand why more teams don't do this kind of work.
Read this for more details:
http://www.sandsmuseum.com/cars/elis...al/asauto.html
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 01-06-2011, 21:57
AdamHeard's Avatar
Lead Mentor
971 works in sheet metal primarily, but I know they've also glued joints in the past. I know it was done on their champion 2009 robot.
Unread 02-06-2011, 09:06
Brandon Holley's Avatar
125 has used a box beam/gusset/rivet setup for the past 3 or 4 years on our manipulator frames.
It makes for a very rugged connection that can be removed if necessary, while also keeping a very square frame which is extremely important to us. The frame also is extremely light which is obviously important as well. We have the ability to weld, and will do so in critical areas, but the rivet/gusset system has worked great for us so far.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 02-06-2011, 09:27
Chris is me's Avatar
AKA: Pinecone
We welded for the first time this year and loved the light, RIGID result. We welded what we knew would be on the robot in week 2, and used gussets and rivets for later additions. These held up just fine.
Unread 03-06-2011, 16:44
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
We welded for the 2010 season. What we didn't discover until after the competition was that the welding had twisted the AL frame enough so that the wheels weren't riding evenly. We had clues before the competition, but we didn't catch them. To fix we ended up putting spacers in to make the wheels ride evenly, then we had a lot better performance.
Our students did the AL welding. Having an experienced AL welder probably would have prevented our problems, but then our students wouldn't have learned.
-T
Unread 01-07-2011, 19:07
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
I have to ask, why use tubing at all? Check out my team's (1501) building method. The best thing we ever did was to embrace monocoque construction. We use 0.040" thick pre-painted aluminum sheets for 90% of our structures and I believe our bots have shown their strengths over the past few years. Monocoque structures can be built with simple hand tools and even rookie students can be making usable parts with minimal training. We have embraced it, it has done us well, it looks good and you don't have to wait for the paint to dry!
Unread 05-07-2011, 01:27
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Reported.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
