Go to Post That's just the thing about plastic or brass gears; they tend to morph into plastic or brass washers real fast. - Nick Seidl [more]
Unread 04-06-2011, 00:23
Johnny_5's Avatar
Johnny_5 Johnny_5 is offline
Whose cooking motor?
AKA: Isaac
FRC #3484 (Short Circuit)
Johnny_5 has a spectacular aura aboutJohnny_5 has a spectacular aura about
Problem downloading code to c-Rio
As I was preparing our code for use at a science camp demo, I experienced a problem I had never seen before on the classmate.
As I was downloading the code to the c-Rio(not in a build/deploy, just temp) and the classmate was tethered to the c-Rio it got to about 75% when it said it had lost comms with the rio and about 10 seconds after that the classmate just turned off.
As I look at it right now I turned it back on and the 2GoPC logo came up and I hit tab to skip logo boot because it was not doing anything. And now it is on the bootloader page with the status bar for W7 with nothing happening.
Anyone have any ideas?
Unread 04-06-2011, 01:04
torihoelscher's Avatar
torihoelscher torihoelscher is offline
Wow I feel old
AKA: Princess Leia
torihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant future
Send a message via AIM to torihoelscher
Re: Problem downloading code to c-Rio
I dont know about the computer but for the C-rio I would make sure that the wireless is off, the firewall is off, and make sure you have the correct I.P address on your computer. If those dont work, use the cursed word reimage it should work once you troubleshoot it. It works for Team 79!!
Tori Hoelscher
FLL
FTC
FRC
"May the [mass x acceleration] be with you"
"Aren't you a little short to be a storm trooper?"
Alumni of Team 79 Krunch.
Unread 04-06-2011, 01:26
Fletch1373's Avatar
Fletch1373 Fletch1373 is offline
AKA: Fletch
FRC #3181 (Panthers)
Fletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud ofFletch1373 has much to be proud of
It almost sounds like your classmate's battery was low and put itself into hibernate/standby. That would cause the loss of comms and it turning off. Could you better describe (or take pictures) of the classmate starting up? I'm having difficulty understanding what it's doing.
Student:
<04: FRC0213> <05-08: FRC1373>
Mentor:
<09-10: FRC0809> <11-12: FRC3555> <12-14: FRC0073> <15-??: FRC3181>
Volunteer:
<FTAA> <CSA> <Defense Coordinator> <Scorekeeper> <Robot Inspector> <Official Scorer>
2016 Tour:
CTWAT [DefCoord] > Pittsburgh[Mentor/DefCoord] > TVR[FTAA] > FLR[CSA] > NE DCMP[CSA] > CMP[CSA]
Unread 04-06-2011, 08:33
Johnny_5's Avatar
AKA: Isaac
The classmate was plugged in when the code was being downloaded. And after it lost comms then it shut down, and not a normal shutdown sequence. It just turned off.
When I went to turn it back on it was froze at the 2goPC logo until I hit the <tab> key to skip the logo boot. And after that it went to the windows 7 status bar where it then totally locked up. Normally the status lines go across the bar as windows is loading but this time nothing was happening
Unread 04-06-2011, 10:04
If the Windows 7 loading page stays up, then I'd think it wasn't a battery problem, but the Classmate not being able to properly access either memory or drive. It sounds like it can access the bootloader and BIOS.
Possibly reseating the hardware might help.
Reimaging is a last resort if you have your user files/code backed up somewhere.
Unread 04-06-2011, 23:06
Fletch1373's Avatar
AKA: Fletch
I'm with Mark on this one. It's definitely getting through the BIOS and bootloader. Seems like RAM may have been loose and was unseated during the download. Try to get into the BIOS page and see how much RAM is listed. If it's different than what the machine actually has, I would open the bottom and try reseating it. It's also possible that there's a corrupt system file(either by virus or other means). I would check and reseat the RAM, then try booting into safe mode with F8.
Let us know how it goes!
Student:
Mentor:
Volunteer:
2016 Tour:
