Go to Post When teams work together to design things rather than going it alone, you can really come up with magnificent machines. - JesseK [more]
Unread 05-06-2011, 15:41
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
pic: Exploding Bacon's Spamthingamicon! (Octocanum)
Unread 05-06-2011, 15:42
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: Exploding Bacon's Spamthingamicon! (Octocanum)
that is an absolutely incredible cad job. I'm curious what software you use and how long all those renders took.
Unread 05-06-2011, 16:02
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
Oh. My. Goodness. I don't think there is a word in any language that can describe this CAD model...
How long did it take?
Unread 05-06-2011, 16:08
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
You may want to consider swapping which wheel you have articulate. If I understand these pictures correctly, right now you have your traction wheels on the jump drive, which means if you take a lateral hit while in traction mode you risk trashing your modules.
D5 Robotics: Member since 2007
Drive Team Coach, Design Mentor
Palmetto Regional attendee 2007-2011
2009 QF, 2010 SF, 2011 SF
Unread 05-06-2011, 16:16
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
AMAZING!!!
Why did you choose to go with lightened sheet instead of thinner, non-holed stock?
Unread 05-06-2011, 16:25
AKA: Andrew Remmers
First off Thanks for the awesome comments!!!
I used Autodesk Inventor 2011 for this model and this was my very first sheet metal drive train. I rendered it in Autodesk Showcase and since I didn't really know what I was doing when I made these renders they are actually VERY low quality! They only took about a minute or so to make!
The entire model since it was my first drive train ever took about a month total with something like 3-4 Iterations However it could have taken a much less time but I was pretty busy during that time so it was very much neglected for a while.
Yes they do tilt on the mecanum shafts, and if we were going to actually build this now It would be updated a ton! However I really like my choice of the Cylinders! They are purdy and actually really light compared to the other ones I was going to get!
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 05-06-2011, 16:27
AKA: Andrew Remmers
Originally Posted by lemiant View Post
AMAZING!!!
From what I understand our sponsors have ALOT of .125 sheet laying all the time so I designed accordingly. We don't want to have special orders made for us when he cuts and bends everything completely free already! (even if a sheet of AL isn't really THAT crazy expensive)
- Andrew
Unread 05-06-2011, 16:33
Starke Starke is offline
Producer at The RoboSportsNetwork
AKA: Matt Starke
FRC #0174 (Arctic Warriors); (Alumni: 340 (GRR), 1126 (SparX))
Starke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond reputeStarke has a reputation beyond repute
Originally Posted by Joyride_67_1902 View Post
Andrew,
Great job! Consider adding it to FRC Designs, which now include a frame subsystem page! See the CD Thread below and send me a PM if you are interested! Excellent work!
FRC Designs Thread: http://www.chiefdelphi.com/forums/showthread.php?threadid=95300
Matt
Team 340 | G.R.R. | Alumni/Mentor | 2003-2007, 2010
Team 1126 | SparX | Engineer | 2008-2009
FRCDesigns.com | Engineer | 2011 - Present
Team 174 | Arctic Warriors | Advisor | 2012 - Present
Unread 05-06-2011, 18:25
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Phenomenal job! When will they be up for sale!
1058 PVC Pirates 2016 - xxxx
Unread 06-06-2011, 01:28
Ankit S.'s Avatar
Originally Posted by Starke View Post
Andrew,
Matt
About that, it seems that you need to click on robot designs and select a year or click on the helpful links before you are even given the option to view subsystem designs.
Perhaps changing it so that the subsystem design tabs are visible from the get-go or so the drop down menu allows you to choose between subsystem designs or whole designs?
Unread 06-06-2011, 07:31
AKA: Matt Starke
I am not sure what you are talking about here. I have included a picture below of the home page of FRC Designs which shows the drop-down menu of subsystem designs. Make sure to refresh the homepage. I hope this helps!
Matt
Unread 06-06-2011, 07:42
Andrew,
What a great drawing and render. Nice Job dude!
Unread 06-06-2011, 09:11
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
That is a wonderful render and beautiful cad work. Great job.
Throughout the past 6 years of team 1902's existence; your students, parents and mentors have become an inspiration to all Florida teams. You guys continue to grow in all aspects of the FIRST programs.
Unread 06-06-2011, 11:17
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
That was a lesson 148 learned in 2010. Our 2011 pre-season prototype and our 2011 robot had stationary traction wheels -- MUCH tougher.
-John
Unread 06-06-2011, 11:25
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
any relation to the original spamthingacon?
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
