Go to Post This is going to be leet. Or something like that. I can't wait. - Billfred [more]
Unread 09-06-2011, 19:20
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
BaneBots
I have seen lots of talk of the shorts in the BaneBot 775. Would it be a better idea, next year, to use two smaller motors instead of one 775, or is this problem with all banebots?
Unread 09-06-2011, 19:27
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: BaneBots
It all depends, I would much rather use a FP than any BB because it has more gearboxes it can adapt to, and last year BB had a horrible rate at witch they got there products to you. But we zapped our rs-775's and they worked fine.
Unread 09-06-2011, 19:49
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: BaneBots
I would just use a 550.
It has the EXACT SAME mounting pattern as the FP, the power output is almost as much as the 775 (~250 vs ~265 watts), it's slightly lighter (which unfortunately means it is more power dense and will heat up faster), and the output speed is comparable to a FP (within 10%, close enough to mate them directly).
Just so everyone knows:
The -0673 (2011) FP has more power than any single Banebots motor (I calculated 291 watts).
Kettering Motorsports
Unread 09-06-2011, 20:00
MattC9's Avatar
Re: BaneBots
Do you think they will let us use more FP's next year?
Unread 09-06-2011, 20:07
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: BaneBots
i wish they gave us more FP motors. we burned like 5 this year, but now that we know how to deal with them, i think that they could be pretty sweet. i think the rs550's in a double doozy is a bout the best you can get short of a cim for complete durability and power.
Unread 09-06-2011, 20:36
Re: BaneBots
nominal max power ratings for 550 & 775: 247 & 271 watts respectively.
Unread 09-06-2011, 21:02
PatrickBrew1086's Avatar
PatrickBrew1086 PatrickBrew1086 is offline
FRC #0401 (Copperhead Robotics)
PatrickBrew1086 will become famous soon enoughPatrickBrew1086 will become famous soon enough
Re: BaneBots
My team, 1086 Blue Cheese, thought the same thing after having a CIM on our elevator at our first regional and tested with the single FP between our first and second regionals. After finding that the FP stalled we tried the Double Doozy on a custom gearbox we made, which was basically a flattened out ToughBox due to size restraints in the space around our elevator. Originally we had problems with the pinion gear teeth sheering off, turns out they were created out of a bad batch of metal. Of course AndyMark express shipped us 5 or 6 more out of a good batch and we never had one sheer again. Back to the point of this post, we found that under the stress we put our 2 BaneBots 550's under in our elevator was enough to burn them out about every 2 to 3 matches. The problem even continued when our elevator had two constant force tension spring helping each stage up individually. Hope our experiences with this help!
Patrick Brew
First Team 1086 Blue Cheese
Unread 09-06-2011, 21:28
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: BaneBots
At this time, we have no idea what motors we'll get to use next year. I doubt that we'll get known defective motors.
Unread 09-06-2011, 23:06
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Re: BaneBots
We don't even know if we're allowed to use aluminum next year (1714 FTW)
If we get guaranteed good parts, the KoP may jump to $7K.
wow. two smilies in a row. I better take my temperature.
Hi!
Unread 10-06-2011, 00:59
MattC9's Avatar
Re: BaneBots
Wait what no aluminum?!
Unread 10-06-2011, 01:02
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: BaneBots
Yep totallly illegal and not allowed
-RC
R.C.
MadTown Robotics Team 1323
Unread 10-06-2011, 01:24
MattC9's Avatar
Re: BaneBots
Good thing were learning how to use carbon fiber & polyurethane this off season
Unread 10-06-2011, 08:19
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: BaneBots
Patrick Brew
Our story is exactly the opposite of this. We had one RS-550 on our 4 bar arm all year long. The 256:1 gearbox wore much faster than the rs-550. During one match, we had part of the surgical tubing break, and the rs-550 let off a bit of smoke and heated up because the far to intense for the gearing. The motor still ran strong for 15 more matches.
The rs-550s will get hot if you put them in a situation where they endure ~>50% load for 10-15 second intervals with short breaks inbetween. However, we stalled the motor (by accident) giving it ~20% power for 15 minutes or so with only mild heating of the motor.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 10-06-2011, 10:04
Re: BaneBots
Did you really mean you gave it 20% power?
At 12 volts at stall, you are giving it 1020 watts of power. 20% of that is 204 watts power. I doubt the 550 could dissipate 204 watts for 15 minutes with only mild heating.
Maybe you meant you gave it 20% voltage?
20% of 12 volts is 2.4 volts. At 2.4 volts at stall, you are giving it 41 watts of power. Even at that lower number, the 550 would get pretty warm after 15 minutes.
Unread 10-06-2011, 10:28
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
Re: BaneBots
Any company that mass produces a known defective or dangerous KOP item and them refuses to support the repair and/or replacement of that item should be unceremoniously DUMPED as a sponsor. And if FIRST invites such sponsors back then shame on them.
It is pure coincidence that I am writing this opinion in this particular thread.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
