Go to Post Sometimes dumb ideas just work really well :P - Garrett.d.w [more]
Unread 10-06-2011, 10:30
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Re: e-watt LED light bulbs - what has been your experience
If the bulbs were wired in series, they would not operate properly. Each one requires the full 120 volts.
The 120v light bulbs in your home are all wired in parallel, and you can turn them on and off individually, and the wattmeter on your home reads the sum of the power they use.
So If you had a switch on each bulb in the display set up you could turn them on one at a time to show how much power they use right?
Every day is a new adventure!!!
