Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Go Back   Chief Delphi > Technical > CAD
Unread 11-06-2011, 12:30
Kusha's Avatar
Kusha Kusha is offline
Crimpin' ain't easy
AKA: Kusha Gharahi
no team (Looking for a team)
Kusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the roughKusha is a jewel in the rough
Re: My first chassis in cad progress.
Originally Posted by msimon785 View Post
Nice job, Kusha!
Your CAD has definitely improved- exponentially. A few suggestions. 1) You'll see the C stock on the front and back has an orange border. you have a sketch with nothing on it. if you double click the part to open it, you can either delete the sketch, or remove its visibility.
2) The bolts- while CADing them like this works, I would suggest using the bolted-connection generator under the "Design" tab on the ribbon. It's efficient and works really well. how to.
Good Luck!
Ahh, I wish I knew about bolted connections earlier, that is so much easier. I think I'll go ahead keep the existing connections and use bolted connections. After I'm done I'll replace the existing ones with bolted connections.
EDIT: Got the orange stuff removed!
Question: I remember in 2010 there was a little on the left side that I could pick out indivdual things I've done and modify/delete them, any idea where I can enable that in '11?
“Be the change that you wish to see in the world.”
― Mahatma Gandhi
