Go to Post More to the point, stop worrying about whether your "Atlanta bot" got screwed over or whatever. Worry about whether you've got an "Atlanta team." - RebelWithARobot [more]
Unread 10-06-2011, 13:52
Micah Chetrit's Avatar
Micah Chetrit Micah Chetrit is offline
FRC #3276 (NSR)
Micah Chetrit is on a distinguished road
Relay to control 2 outputs
Hey everyone.
I have an off season project to make LED rods and put them on the robot and get them to light up in patterns (I am also a programmer). Being that there are going to be 4 rods, I thought I could save space and money by using only two Spike relays, attaching two Positive wires to it and using a common ground that isn't run through a relay.
If I recall right, this has been used for solenoids (? might be wrong). In my mind it should work, is there any reason it shouldn't?
Secondly, is it legal to control two outputs with one controller? (haven't read rules for a long time, I forgot many of them)
Thanks in advance,
Micah
Unread 10-06-2011, 14:31
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Relay to control 2 outputs
This is an off-season project, legality is not an issue.
There is no reason why it wouldn't work. In LV at least, the Spike has four output states (Off, Forward, Reverse, and On). Fwd will set one on and the other off, Reverse will set the second one on and the first one off, and On will turn them both on.
Kettering Motorsports
Unread 10-06-2011, 16:39
FRC #3276 (NSR)
the reason legality is an issue is that I am making two sets, one for the current bot, and one for next years bot (using the same code)
Unread 10-06-2011, 17:05
O-H
FRC #0048 (Delphi E.L.I.T.E.)
See R42. Controlling 2 solenoid or low-current light outputs with one Spike has been legal for many years. As long as you properly send the negative wires back to a black PD board negative terminal (presumed ok to splice the negative leads to fit into a single terminal), you should be fine.
However, what would not be legal is preparing these LED arrays and wire harnesses for use on a 2012 FRC robot - you must wait to perform all such work after kickoff of the 2012 season, during approved robot work times.
Unread 10-06-2011, 17:13
FRC #3276 (NSR)
Oh, I didn't know about that.
what specifically is forbidden? Can I wire the leds and put them in a tube (therefore just creating a part), but not wire it to a relay? or is making custom parts before season not legal?
Unread 10-06-2011, 17:18
O-H
The latter case is true. Until the rules change, you cannot fabricate custom parts or construct custom assemblies for your official FRC robot prior to the start of the season. This is one of the core tenets of the FRC program - every team must engineer their robot within the same time window.
Unread 10-06-2011, 17:20
FRC #3276 (NSR)
Thank you for pointing that out. I guess I only have to make one set this summer then.
Unread 10-06-2011, 19:10
Micah,
It is also possible that this wiring method would be illegal during next year's game and rules. I would hope that the GDC allows teams to use this method but you never know for sure. As stated the Spike is capable of switching either or both outputs between high and low states. The manual for the Spike explains this.
Unread 11-06-2011, 17:27
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
Micah,
If you connect them to a Jaguar or Victor you could dim them. With different colors that could give you some interesting effects. You would need to put the LEDs in series to be able to tolerate the 12 volts...maybe 6 LEDs and a current limiting resistor. Just an idea...
-Hugh
Unread 11-06-2011, 23:31
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Just as a note, what Travis said is perfectly true; any design done preseason is not legal for use during competition. However, if the design is modified (i.e. improved or optimized during competition) for the robot, then it is indeed legal.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 12-06-2011, 00:19
Warlord Warlord is offline
He-Who-Does-A-Little-Of-Everything
Team Role: Driver
Warlord is a jewel in the roughWarlord is a jewel in the roughWarlord is a jewel in the rough
Although it is worth noting that given that this seems to be more decorative than functional - designing a whole drive train in the offseason is one thing, designing some pretty lights is something else entirely. I wouldn't worry too much about breaking the intent of the "6 weeks" thing.
Unread 12-06-2011, 11:39
Steve Warner Steve Warner is offline
Controls / Programming
FRC #0234 (Cyber Blue)
Steve Warner is an unknown quantity at this point
I don't have the latest version of the C++ WpiLib source code available to look at right now, but I don't think it allows both relay outputs to be turned on at the same time. Could someone explain why the Relay class was written this way and if it can be changed for the next library release.
Unread 12-06-2011, 12:48
Whenever you have access to the web, V20110203rev2259 is available online for browsing.
The only stated differences from V20110203rev2262 are:
1. A NetConsole error in the cRIO that under some circumstances corrupt memory in the cRIO.
2. Fixed an error with the ADXL345 I2C accelerometer.
3. Fixed an error with allocation tracking in the Counter class.
Unread 12-06-2011, 16:02
Thanks Ether. So in Relay::Set there is no way for the kOn case to set both outputs true. I think this is something that could be easily fixed.
Unread 12-06-2011, 20:37
slijin's Avatar
Pockets
AKA: Samuel Lijin
To my memory, I believe controlling the 4 states of a Spike involves splicing together two outputs into the Spike input, though I could be wrong.
