Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
Unread 14-06-2011, 19:32
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Getting the d-link to connect
I have got configured in AP mode, so that I can connect to it with only my computer (using the 2011 bridge configuration document). I can download code wirelessly through netbeans, but the driverstation refuses to connect. What should I do?
Unread 14-06-2011, 21:58
Re: Getting the d-link to connect
If the computer can download, then the only reason the driver station wouldn't connect is that it's probably trying to go out the Ethernet port rather than the wireless.
Fiddle under the Setup tab with choosing the NIC as the wireless.
It may require turning off the Ethernet port until it finds and recognizes the wireless port.
