Go to Post Ahhh... the beauty of an exponential series... - dtengineering [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 29-11-2002, 20:50
DLyons DLyons is offline
#0910 (Ventures)
DLyons is an unknown quantity at this point
Programing of controller
I am new to this, I am looking at the downloading to the RC document from inovation First. the 3rd step is to: set the robot controller program jumper to user.
any ideas?
thanks
team 910
I love FIRST
2003-Seed 8 @ West-Mich Regional
Sad to see I am done on the student side, now I will have to mentor
Unread 29-11-2002, 23:23
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
i forget exactly where, but somewhere on the front of the RC (take care, this is the ROBOT CONTORLLER, not the OI (Operator Interface), there is a little jumper, like on a IDE Hard Drive/CD/DVD-ROM (hey, best example that I can think of, and it's the same idea). One setting is marked to "Default" the other to "User". When set to "Default" the RC will run the default code (it's someewhere at www.innovationfirst.com/FIRSTrobotics). When set to "User" the user can download and run PBASIC programs on the RC. As I said before, the switch is on the front of the RC, i believe on the bottom in the middle.
If you have any other questions, feel free to ask.
<EDIT>I had assumed you were using the 2002 RC, but if that is not the case, i'm not sure where the switch is, although the same idea should hold true (set to user to download and run your own programs).</EDIT>
AIM --> Woloi
Email --> ian@woloschin.com
Unread 02-12-2002, 00:16
rolocroz rolocroz is offline
Junior Member
#0852 (Athenian Robotics Collective)
rolocroz is an unknown quantity at this point
Send a message via AIM to rolocroz
Though I don't have a robot controller in front of me right now, I believe that the jumper is in the bottom right hand corner of the RC. It's just three metal pins with two possible settings. I believe you can see it here.
C controller Rorschach Kit & Additional Hardware 1 29-10-2003 19:21
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
How do you connect the speed controller fans? Iain Electrical 7 31-01-2003 07:05
visibility of robot controller? davidzhang Rules/Strategy 5 26-01-2003 01:11
