Go to Post From past experience members of our team insist on never trusting gravity. - Vash [more]
  #46   Spotlight this post!
Unread 14-06-2011, 23:15
Re: e-watt LED light bulbs - what has been your experience
FWIW:
60 watt incandescent 840 lumens
40 watt incandescent 490 lumens
LED T-67004M (Cool White 5000K) 560 lumens
LED T-67004S (Warm White 2700K) 450 lumens
  #47   Spotlight this post!
Unread 14-06-2011, 23:31
KarenH's Avatar
KarenH KarenH is offline
Mrs. ChrisH
FRC #0330 (Beach 'Bots)
Team Role: Parent
KarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond reputeKarenH has a reputation beyond repute
In the picture I posted--
--the bulbs are horizontal
--the frosted glass shade is below them
--there is no shade above them
--the ceiling is moderately dark (main reason why this room is hard to light)
So maybe my "test" should include a situation such as in a table lamp, where the bulb is upright and lights up the ceiling and walls. One thing I haven't done is to try it at night, when there is no outside light. To be truly "scientific," though, I would have to remove all the furniture and somehow take a picture of the floor, but how could I do that without blocking the light with my camera? Oh, well. I guess the main thing is whether we decide we like it in our house.
Karen Husmann
Ex Robo-widow
  #48   Spotlight this post!
Unread 15-06-2011, 07:33
pfreivald's Avatar
AKA: Patrick Freivald
FWIW:
I know, but all that really tells me is that a lumen rating is a poor indicator of how a bulb 'looks' in a room...
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #49   Spotlight this post!
Unread 15-06-2011, 08:56
Brandon Holley's Avatar
This is an extremely true statement. While lumens are an important metric when evaluating light, there are often many other factors to consider.
When dealing with LED bulbs in particular, higher CCTs (color temperatures) result in a higher light output (for the same drive current). Essentially, higher CCT LEDs are more efficient than lower CCT LEDs because the phosphor conversion of blue light to white light is less dramatic.
Many companies will try and squeak a few more LPW (lumens per watt; essentially how efficient the bulb is) out of their fixtures and bulbs by bumping the CCT up a little bit and essentially gaining free light.
CRI (color rendering index) is another very important measure, albeit a controversial one at times. CRI basically tells you how well the light coming out of the bulb/fixture renders colors. The higher the CRI (max=100) the closer it is to natural sunlight in terms of color rendering. You can read more about CRI here: http://en.wikipedia.org/wiki/Color_rendering_index
One last measure which has a lot of play in LED lighting is lux. Lux is a measure of ILLUMINANCE, not LUMINANCE. Lux takes into account how much light is being emitted over a certain area. In situations which are a direct replacement for incandescent or flourescent bulbs (such as the FIRST bulb) it is not as useful, but for other LED retrofitting applications it is extremely useful. One example of where lux is extremely important is in streetlighting. Streetlighting has very specific requirements for lamps to meet so roads/sidewalks/parking lots are lit correctly. Just putting a big light source in a fixture will not necessarily give you the correct light output. To ensure the beam is being spread and shaped correctly, measuring lux at specific areas of illuminance will tell a better story of how well the light fixture is working.
These are some more metrics that can be useful when evaluating light, and LED lights in particular. As with most things, there are direct tradeoffs between things like cost and efficiency, CRI and output, etc. It is our job as engineers to find a balance that consumers will enjoy!
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #50   Spotlight this post!
Unread 15-06-2011, 09:22
... and they do the opposite (lower the color temperature) with incandescents to create "long life" bulbs.
60 watt standard 840 lumens
60 watt "long life" 770 lumens
Don't forget that the user can easily lower the color temperature and/or change the lighting pattern by selecting a different lamp. A different lamp can completely change the look and feel of the same bulb in a given room. A glass bowl or reflector which directs the light upwards to reflect off the ceiling produces a completely different lighting pattern than a lampshade that is narrow at the top and wide at the bottom to direct the light downward. And a white lampshade produces a different "feel" in a room than a dark color.
  #51   Spotlight this post!
Unread 15-06-2011, 11:06
I have way less of an understanding of how incandescents work so I cannot speak to them as well as LED, but how do you tune the CCT of an incandescent bulb? Just curious, it seems like a pretty interesting thing to do.
Lighting is all about "feel" as you have said. Unfortunately its extremely difficult to put measurable metrics on feel, which is why lighting is sometimes a very tough market to penetrate. As you said, options must be available for users to make their own choices of what feels right to them.
I do have to say however, since I began working on LED lighting around 3 and a half years ago, I now prefer cooler feel temperatures (higher CCT). Nothing in the 4500K+ range, but a 2700K temp actually feels wrong to me now.
-Brando
  #52   Spotlight this post!
Unread 15-06-2011, 12:13
The user can change the color temperature of an incandescent bulb by dimming it.
The manufacturer makes long-life incandescents by changing the filament slightly so it doesn't burn as hot. That gives a yellower light, and the filament lasts longer. And the bulb is less efficient (fewer lumens per watt).
  #53   Spotlight this post!
Unread 16-06-2011, 23:19
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Reported
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
  #54   Spotlight this post!
Unread 20-06-2011, 13:59
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
What kind of watt meter would you use?
What brand? Where would you purchase it?
Every day is a new adventure!!!
  #55   Spotlight this post!
Unread 20-06-2011, 16:32
Cynette Cynette is offline
Worry is a poor use of Imagination
AKA: Cynette Cavaliere
FRC #1511 (Rolling Thunder)
Cynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond reputeCynette has a reputation beyond repute
Send a message via ICQ to Cynette Send a message via AIM to Cynette
Our display has places for 4 bulbs so we can compare the color and directionality of the bulbs. Maybe we should get incandescent bulbs with the warm and cool designations to use in the display.
Karen - I can't tell the difference in your photo. You may have found the perfect application for a 40 watt LED that looks like 60 Watt in one direction!
When I next see our display and /or the builder of it, I'll get the details on the watt meter. All I remember it that it plugged into the outlet and had a digital read-out!
Cynette
The best angle from which to approach any problem is the TRYangle
--Chinese Fortune Cookie
Rolling Thunder, Team 1511: The Thunder just keeps getting louder!
  #56   Spotlight this post!
Unread 22-06-2011, 20:45
PaW's Avatar
PaW PaW is offline
AKA: Paul W
FRC #1899 (Saints Robotics)
PaW has a spectacular aura aboutPaW has a spectacular aura about
Budget-conscious consumer electronics vendor Vizio is getting in on the act... reported here: http://www.engadget.com/2011/06/22/v...es-a-light-bu/
"...A Vizio price..."
  #57   Spotlight this post!
Unread 22-06-2011, 23:37
DonRotolo's Avatar
Back to humble
FRC #0832
Well, I got my first bulb yesterday, and boy are they directional. I have a standard lamp in the living room, and the LED bulb does not cast enough light downwards to read by - while a 60W incandescent is almost too bright.
On the other hand, in a downward-facing ceiling fixture, they are excellent.
Thank you PaW for the Vizio link; using a cheap bathroom light bar as my demonstration board will save me a bit of grief.
As for wattmeters: I am planning to get four $3 Harbor Freight digital multimeters, connect them to show Amperes for each of the four bulbs I want to display (LED, CFL, 40 or 60w Incandescent, 45 or 65W R30). People will see bigger numbers for the Incandescents, that'll be all they need. Done, & done.
  #58   Spotlight this post!
Unread 23-06-2011, 00:48
KarenH's Avatar
Mrs. ChrisH
Team Role: Parent
I wish I could try one in our table lamp. However, we generally use a 150-watt 3-way bulb, so trying any 40-60-watt bulb replacement would not be a fair test!
Karen Husmann
Ex Robo-widow
  #59   Spotlight this post!
Unread 23-06-2011, 11:33
For a user friendly meter you could also use something like this for $21.
  #60   Spotlight this post!
Unread 23-06-2011, 12:30
the man's Avatar
AKA: Jacob Overla
FRC #4004
I would watch out for those meters. I looked at some of the reviews and a lot of them said the meters were prone to breaking. And trying to show a potential costumer watts with a broken meter may not help you sell this product.
