Go to Post We've done all the speculation we can do (some of us with less knowledge than others); let's rest our minds and keyboards and wait. - Astrokid248 [more]
Unread 17-06-2011, 16:26
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
pic: WCD Practice 2
Unread 17-06-2011, 16:27
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: WCD Practice 2
Im currious as to what type of bearings you plant to use, unless it is a dead axle system?
Unread 17-06-2011, 16:30
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
How do you execute dead axle cantilevered wheels?
Unread 17-06-2011, 16:37
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Run the chain outside of the chassis next to the wheels.
Because the sprocket and wheel have the tube between them, I'm going to guess this is live axle.
Unread 17-06-2011, 17:52
Cyberphil's Avatar
That Guy
AKA: Phil
THis is a live axle setup. I designed this around the AM hex bearings (the heavy duty ones).
This picture is without the wheel, shaft, bearing mount and bearing. I did this to show the innards of the design. Any critiques, more questions, or input? I am very interested in what CD has to say about this.
Unread 17-06-2011, 17:55
Chris is me's Avatar
AKA: Pinecone
With a cantilevered wheel, it's probably safer to use 1/2" hex.
Unread 17-06-2011, 18:35
Cyberphil's Avatar
That Guy
AKA: Phil
But Chris, I am using 1/2" hex shafts. that hole is just a clearance hole for the shaft when it rotates. The bearing blocks are connected to that inside block, as you can see in both of the other pictures.
Unread 17-06-2011, 18:45
AKA: Isaak
Team Role: CAD
If you are using .5 hex shafts I might consider turning them down to round where it goes through the tube, or making the slot 3/4 of an inch wide. As it is now, you have about 1/32 of an inch clearance between the slot and the axle when a flat is perpendicular to the slot, if your blocks are even slightly off, or if you powder coat, the axle might start rubbing on the tube.
Edit:
The link you posted is for the 3/8 hex bearing on andymark, I think that is why Chris assumed you were using 3/8 hex shafts,
Unread 17-06-2011, 19:01
Cyberphil's Avatar
That Guy
AKA: Phil
You are correct about the bearing. I meant the 1/2 in ones here.
That is a good idea about the shaft. That is not a big problem either. Anything else?
Unread 17-06-2011, 20:03
AKA: Isaak
Team Role: CAD
I don't know if you have Caded the bolts for the assembly, but currently it looks like they will interfere with the bolts holding your wheel together. You might want to move them farther apart, or make the bolt circle on your wheel smaller, threading outer bearing block is also an option, but it will make your setup more complex.
Unread 17-06-2011, 21:26
Cyberphil's Avatar
That Guy
AKA: Phil
I am a bit confused as to what you mean by bolts holding the wheel together. The mounting holes on the performance wheels are for sprockets and gears and the such, which I am not using. There will be no bolts in those holes. But even if there were, the bearing mounts are counter-bore so the heads of the bolts are flush with the top of the bearing mounts.
My next step is to put all of the bolts in place.
Unread 17-06-2011, 21:28
AKA: Isaak
Team Role: CAD
that answers my question. i was wondering if you were using something like Placticons and a hub, with the performance wheels though there is no hub.
Unread 17-06-2011, 21:48
Cyberphil's Avatar
That Guy
AKA: Phil
Exactly. Just a hex bore. I will probably use snap rings and some spacers to keep everything tight.
Unread 27-06-2011, 23:02
bauer5152 bauer5152 is offline
Junior Member
bauer5152 is an unknown quantity at this point
Edit:
I also think so.
Unread 28-06-2011, 00:40
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Reported.
Team RUSH Alumnus and Mentor, Mechanical Engineer
