Go to Post Please don't complain about the party that was thrown in your honor because they didn't use your favorite color of balloons. - Taylor [more]
Unread 08-06-2011, 20:32
electron's Avatar
electron electron is offline
Former Team Overdrive member
AKA: Joseph
FTC #2753 (Team Overdrive)
electron is just really niceelectron is just really niceelectron is just really niceelectron is just really nice
[FTC]: Custom Material and Wiring Questions
Hello all!
While reading the TechnoGuard's Engineering Notebook (Thank you so much for opening that up, btw!), I noticed the use of what looks like stock aluminum C-Channel for angled bar. You can see what I mean here, and here.
Is that really some sort of stock channel/angle bar? Can I just grab some at the home depot down the road, and (most importantly), is it legal to use in FTC?
I noticed too that they used Kydex extensively, and I'm wondering if anyone has a good supplier that they would recommend.
And one more quick question I have is this:
I noticed that they extensively used custom sensors. Does anyone have a good guide for wiring the protoboard?
Thanks for you help, everyone!
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
I may be one of the few people that has moved from FRC to FTC, and enjoyed it
Unread 08-06-2011, 21:20
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: [FTC]: Custom Material and Wiring Questions
You can use Aluminum U(C) Channel, L Bar, and I think Square (been a while since I have read the rules)
I however don't thing you can get this from your local Home Depot or Lowes (Doesn't show up on the website) However Im pretty sure you could get it from an Ace Hardware or something like that.
You can get Kydex from Mcmaster.com as well.
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 08-06-2011, 22:07
electron's Avatar
AKA: Joseph
Andrew, thank you very much, I (finally) found the page in the manual that allows for Aluminum channel (page 28). I'll look around for suppliers of the aluminum materials, and I found the kydex on mcmaster carr.
Thanks!
Unread 08-06-2011, 22:20
Joe,
Check your manual for allowed sensors as well. I read it as NXT or Lego sensors only.
Unread 08-06-2011, 22:33
Billfred's Avatar
Billfred Billfred is offline
Probably 98.2815% of the aluminum on our FRC robot's arm tower this year was sourced from Lowe's. Home Depot also carries a selection, though I'm not as familiar with its precise offerings.
Unread 08-06-2011, 22:52
electron's Avatar
AKA: Joseph
Joe,
Mr. Skierkiewicz, on page 29-30, rule d (especially d.5) allows for custom circuits to be used, as long as they fit within some specific guidelines, but thank you for you word of caution.
Also see the Inspection list:
No electrical components have been nodified from their original state except the HiTechnic Prototype Board.
Unread 09-06-2011, 01:59
ryanftc2827's Avatar
ryanftc2827 ryanftc2827 is offline
AKA: Ryan Carson
FTC #2827 (Artificial Stupidity)
ryanftc2827 is an unknown quantity at this point
I would highly recommend kydex to all teams, great plastic. Heat forms very well and is very durable. We used it all over our robot for most everything.
Check out our team's new website!
Unread 15-06-2011, 09:03
NalaTI NalaTI is offline
AKA: Alan
FTC #2848 (Techno Guards)
NalaTI is just really niceNalaTI is just really niceNalaTI is just really niceNalaTI is just really nice
Originally Posted by electron View Post
Hello all!
You're welcome!
We did use channel at first because of size, (it's slightly smaller than the Tetrix channel). But then ended up using the square stuff for structural strength instead (which is what's in the pictures) -- you can find it at McMaster (http://www.mcmaster.com/#aluminum/=cra6bh)
Interstate Plastics (http://www.interstateplastics.com)
We used all four plastics BTW. On the final robot, the upper shields were ABS, the lower ones were Kydex, the Hand (and lots of other small pieces) were PETG, the paddles and a few other clear pieces that needed to be strong were Polycarb. We used thin Kydex as covers for parts of the hand as well...
On the prototype board we used three potentiometers, 4 switches, and a hall effect sensor. They show how to wire all of these to the prototype board in the Experimentor's Kit manual (http://www.hitechnic.com/downloadnew.php?category=19).
As an aside, on the prototype board, once we figured out how to use this, it became a nice thing, but for most teams, it's not needed. We waited to tackle it until their third year, and partly used it so Gavin (our programmer) would have something new to learn! We also re-built at least four extension boards. If you are going to look into using this, definitely consider getting the prototyping sensor kit. Being able to build it without solder first was a great tool.
We also used four other sensors (two gyroscopes, an accelerometer, and the I/R Seeker) all with the sensor multiplexer (which we used last year).
Unread 16-06-2011, 07:52
Joe,
I read R5 as only NXT or RCX sensors may be used. Specifically b.4, b.7, d.4 and d.8. The Q&A did allow the use of reed switches with some very specific limitations. That is all that I was able to see.
Unread 16-06-2011, 10:08
electron's Avatar
AKA: Joseph
Mr. Skierkiewicz, I was under the impression that certain custom sensors (eg, potentiometers, some limit switches, and some reed contacts) are considered "modifications", "additional circuits", or "sensors" connected to the prototype board. (see all rules in d. pages 29 to 30).
Also, see post #28 on the GOI Q&A Electrical page here.
Unread 16-06-2011, 14:11
Joe,
R5 d really doesn't allow even the micro switches so the Q&A for reed and microswitch is a waiver made by the GDC. Note that the inspection checklist does not have a spot for these devices. Also if you search you will find that toggle switches also were deemed legal in January after many regional events had already taken place. As you are not modifying any FTC or NXT parts these are not considered legal modifications to use such parts. I did not find any reference to the use of pots, have you? Although I have been a lead inspector for FTC, I do not have any additional input to the GDC for FTC. A strict reading of the rules, in my mind, prevents the use of these devices. That does not mean, however, that I think they should be banned. I personally would like to see the rules in this area opened to the same use as in FRC. All of the stated devices are legal in FRC and encouraged. The real issue is the ability for a team to correctly use these items with the interface tools allowed and prevent damage to the NXT.
Unread 17-06-2011, 22:23
electron's Avatar
AKA: Joseph
Joe,
[snip].
I could not agree more! I used to be the electrical guy on Overdrive's FRC team, and I really miss the open-nes with which FIRST viewed COTs sensors in FRC.
Hopefully, they will address custom sensors more clearly in next year's manual
