Go to Post The closest thing to "Senior Mentor" we have is "Team Grandma". :) - Alan Anderson [more]
Thread Tools Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Unread 20-06-2011, 01:33
ahwei ahwei is offline
ahwei is an unknown quantity at this point
PID line follower vex
As im new in VEX...Can anybody tell me if i can implement PID control using easyc? Because it is the only software i got... If yes, can somebody send me the standard code for it...I need it for my project really much... I will appreciate some help expertsss....
Unread 20-06-2011, 08:03
svenw svenw is offline
FRC #3683
svenw is a jewel in the roughsvenw is a jewel in the roughsvenw is a jewel in the rough
Re: PID line follower vex
I recently found this as I was looking for how to do PID loops with lego. It explains how to make a PID controller and gives the pseudo code.
Hopefully you find it as helpful as I did.
http://www.inpharmix.com/jps/PID_Con...ms_Robots.html
Unread 20-06-2011, 10:58
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
You can implement just about any sort of feedback loop in EasyC (PID is not the only form of feedback-loop control algorithm).
As the algorithm gets more complex, you will want to switch to EasyC Pro because the icons and flowcharts of ordinary EasyC become to bulky and hard to read/maintain.
Up until you stumble over some way to confuse the EasyC compiler. the only limits are the speed of the computer you are using, and its storage capacity. You are far more likely to have trouble with either of those before EasyC will fail you.
Go to the www.VexForum.com web pages and do a search there. There are discussions and sample code for implementing feedback loops to follow lines.
Blake
Unread 13-01-2013, 17:26
Jacoblint228 Jacoblint228 is offline
Jacoblint228
FRC #0228 (Gus Robotics)
Jacoblint228 is on a distinguished road
PID control for vex
Does anyone know where you can set a PID loop where the motor will not move unless the driver drives it?
Jacob Lint
Gus Robotics First Team 228
Unread 13-01-2013, 17:48
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Normally you have a motor that drives some device (like an arm). There is some sensor (like a potentiometer) that tells the position of the arm. The PID code drives the motor until the sensor says it's in position. Then it stops moving the arm.
Based on that, I'm not sure what you are looking for. Can you be more descriptive in what you want?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-01-2013, 20:32
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
I think what Jacob is asking for is a method to have the PID not run if the joystick value is 0. If there is no tolerance, the PID loop will try to tune a value of 0 on the drivetrain, which does take unnecessary processor power. One thing I would do is set a limit, maybe + or - 0.1 on the joystick. Once this value is exceeded, then the PID loop could start running.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
