Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 20-06-2011, 13:02
M. Mellott's Avatar
M. Mellott M. Mellott is offline
CAD God
AKA: Mike Mellott
FRC #3193 (Falco Tech), FRC #48 (Delphi E.L.I.T.E.), FTC #9980 (FMF)
M. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud ofM. Mellott has much to be proud of
Re: Drive train wheels idea
Omnis on all four corners make things difficult--more difficult to control, and lack of ability to resist being pushed or turned.
Perhaps you could put omni/trick wheels only on either the front pair or back pair of wheels and remove the 1/8" center drop. This maintains all 6 powered wheels on the ground at all times, removing the minor rocking due to the drop center, but it increases the manueverability without loosing contol. Teams 48 and 3193 did this with great success this year, using custom 4" treaded wheels (modeled after the AM peformance wheel) with 4" omnis up front. The robot was very maneuverable, very stable, and had no issues being pushed/turned.
Two notes: we made the custom treaded wheels 1.5" wide instead of the standard 1", and we located our main mast/arm at the center of the 4 traction wheels.
In the continuing battle between innovative engineering and the laws of physics...physics always wins.
Unread 20-06-2011, 16:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Factors that I'm surprised haven't been mentioned yet:
Motor selection
Gear ratios
Tread selection
Wheel placement
Unread 20-06-2011, 19:47
Micah Chetrit's Avatar
Micah Chetrit Micah Chetrit is offline
FRC #3276 (NSR)
Micah Chetrit is on a distinguished road
Tread selection
Which have teams had better success with (From andymark) as far as traction wheels go? Rough top or Wedge?
Unread 20-06-2011, 20:03
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Here: http://www.andymark.com/product-p/am-0014.htm
it states that roughtop has slightly higher CoF. As far as tread wear goes, hopefuly someone with more experience with both treads can chime in.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 20-06-2011, 20:36
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
Tip of the day: Do not waste your time trying to improve drivetrain performance when the kitbot is so good!
My team ran a 6WD Kitbot with 4" Plaction Wheels and Supershifters from Andymark. It was the most reliable and effective drivetrain I have ever been involved with. If you preped the parts prior to build season, it literally takes a couple hours to put together and build (lead times for parts were the only reason we were just driving in week 2). I have seen lighter drivetrains, but the weight we had on it was only 2" off the ground, dropping CG of the robot.
Focusing on the mechanisms that get you points will make you more competitive than building what is essentially the kitbot, but lighter. Engineering is all about picking the most efficient areas to make gains.
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 20-06-2011, 23:36
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
The kitbot this past year wasn't as good as it has been from 2010 back to when andymark started providing it. They stopped including toughboxes in favor of the lighter, cheaper CIMpleboxes, which is fine, but they still gave teams 8" wheels. The since there is less torque due to less reduction, the 8" wheels required the motors to work harder and at a less desirable point on the performance curve. This can cause power failures, especially during turns, since the voltage drops far enough for some parts of the system to brown out or otherwise lose power.
My tip of the day: match you wheels to your transmissions and regardless of whether or not you use the kitbot and/or its frame.
Unread 24-06-2011, 16:17
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I generally prefer roughtop to wedgetop for carpet driving, and haven't really giving much effort into determining whether or not that would change if we were driving on another surface (such as different carpet, aluminum, polycarbonate, PVC, or HDPE). Keep in mind that there are also alternative tread materials, in addition to the roughtop vs. wedgetop distinctions.
McMaster has numerous options. So do other places (Brecoflex, Gates, etc).
Unread 25-06-2011, 02:24
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Wedgetop tends to wear out much faster in my experience; on our 2010 bot, we had a 1/8" center drop, roughtop centers, wedgetop corners. Wedgetop tread had to be constantly replaced, about every 4-5 matches. The roughtop was placed in the center for traction; wedgetop on the corners to facilitate turning.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 25-06-2011, 17:14
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
I don't think the problem discussed above has to do with the normal tread wear properties. It probably has to do with your weight distribution. I'm going to guess you have most of your weight on the center wheel and rocked quite a bit during the match. And with a 1/8" drop the wedgetop on the corners would most defintely be scrubbing. Especially because wedgetop is a tiny bit thicker than roughtop (making the effective drop even less).
Let me know if I'm right.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
Unread 25-06-2011, 19:16
Chris is me's Avatar
AKA: Pinecone
Maybe, but I do know that wedgetop seems to wear faster than roughtop.
Unread 25-06-2011, 20:00
AKA: Alan Wells
FRC #1350 (Rambots)
Wedgetop wheels have narrow, tall ridges which means less of the tread transmits the same force compared to roughtop. This seems to fit the anecdotal accounts of wedgetop wearing out faster.
If wheels were a dirt road, roughtop wheels would be a dirt road where the cars pass over all of the surface evenly resulting in even ware; Wedgetop, on the other hand, would be a road where cars only travel down the center resulting in ruts in the road.
Unread 25-10-2011, 23:37
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Originally Posted by Hawiian Cadder View Post
.....if you want to make a tunable robot, i would take a look ate 1986 team titanium's robot from this year, they used an 8 wheel tank drive, with omni wheels on the ends, and were amazing, because it still has 4 traction wheels, it doesnt turn too easy, but turns better than a standard tank drive.
you might try reducing your gear ratio some if you want to turn better, even just 5 percent will make all the difference in the world.
in summary;
if you want to use omni wheels on the ends, use 8 wheels total, 6 turns way to easy and its easy to get spun, and the plastic omni wheels are the best option as far as cheap, versitile, durrible, and lightweight.
Edit: here is a video showing 1986's drive train, if you want an drive with omni corners to learn from, theirs is very good.
http://www.youtube.com/watch?v=DdnYpgoClW4
Here's a much better view of our 8-wheel in action.
http://www.youtube.com/watch?v=WPD82b-y6dc
