Go to Post It's good to learn from experience. It's better to learn from somebody else's experience. - Jay TenBrink [more]
Unread 22-06-2011, 18:48
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
Re: Jaguar communication issue
Originally Posted by jhellr13 View Post
According to what you have said, I think the Jaguar is fine. Plus is you used it for competition they are definitely calibrated then. If you didnt know, to calibrated you take a small pin and put it in the reset hole. Then you wait for it to blink. Then you just push the joystick forward, neutral, then back, then release pin.
Are you sure pwm is only for that Jaguar and not used for something else?
The last thing I can think of is the following. If this Jaguar is for your drivetrain, then you have it programmed wrong. If it is just for a window motor which should he attached to a spike relay, you also have it wrong. What exactly are you using this Jaguar for? I probably should've asked that in my first response.
I am using the Jaguar for a drivetrain CIM motor. Frankly, I've never had different programming for different motors, so I am not entirely sure what you mean.
Originally Posted by Mark McLeod View Post
Did you accidentally open PWM2 for some other device as well?
It's often not the code you are focused on that causes problems, but the code you dismiss out of hand as "unrelated".
No, I've only opened PWM2 once. Woah, that scared me for a second.
An additional thing I should note was that once I removed code from the Disabled.vi and PeriodicTasks.vi dealing with the two motors (no longer referenced in the Begin.vi) from the demo code, I have no errors pop up when operating the robot. Before I removed that code, I had many, many errors from those two pieces of code.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
