Go to Post In the end, you get out of FIRST what you put in. - BlueLipstick [more]
Unread 23-06-2011, 17:56
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
pic: As suggested - six robots
Unread 23-06-2011, 17:57
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Re: pic: As suggested - six robots
nice, you must have an incredibly boss computer.
Unread 23-06-2011, 18:25
Actually, that's what I was testing. My old computer died so I bought a new one. Intel i7 960, 3.2 GHz, 12 GB RAM, ATI FirePro V5800 Graphics Card.
My old computer struggled a bit with our complete Logomotion robot so I went a bit over the top on the new computer. With the full game field and 6 robots it is just a bit slow but basically performs pretty well.
I'm running PTC's Creo Elements/Pro 5.0. Version 5 is a big improvement over Wildfire 4.0 for rendering.
Unread 23-06-2011, 21:02
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Tom,
Would you be willing to email me a zip file of your robot and the field?
Joe
Unread 24-06-2011, 05:36
Sure. The field you can get from here: http://www.catalogds.com/db/service?d=first&c=browse
What format would you like the robot model in? It's native format is for PTC software but I can generate a step file if you like.
Unread 24-06-2011, 07:52
.step would be great.
Thanks
Unread 24-06-2011, 15:54
I have the step file ready. The polycarbonite side panels came through opaque and the sponsor sticker graphics didn't translate but the rest looks good.
I'd upload it to CD-Media but the last time I tried it didn't work.
PM me your e-mail address and I'll send it. I'll use wetransfer.com to send the file.
Unread 24-06-2011, 16:10
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Any other notable differences between 5.0 and Wildfire? I've only used Wildfire and trying to figure out whether it's worth the upgrade.
Unread 24-06-2011, 17:09
They did make quite a few changes that I really like. For example when an assembly part fails, you don't have to tell it to "freeze" that part and every child part for the rest of the assembly. All parts are just flagged in red and you can fix it when you want.
Unread 24-06-2011, 17:57
emekablue's Avatar
emekablue emekablue is offline
AKA: Eunice
FRC #1671 (Buchanan Bird Brains)
emekablue is a jewel in the roughemekablue is a jewel in the roughemekablue is a jewel in the rough
How do you get the sponsor stickers on parts in pro-e?
Unread 24-06-2011, 21:32
Make one part for each sticker. The part is the exact size of the sticker and has some small thickness. Then go into the appearance manager and attach a jpeg of the actual sticker to the surface of the part using the decal option.
The sticker parts can then be assembled onto the surface of the model where they belong.
Also, the jpegs need to be in the working directory to get loaded automatically when you open the model.
Unread 24-06-2011, 22:18
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
That's long overdue. It was the biggest reason why the learning curve for Pro/E was so steep. (Although you eventually get used to building things in a way that mitigates the consequences of part resolution failures, when it happens, it's always annoying.)
Unread 24-06-2011, 22:23
Incidentally, has anyone figured out how to loft the fabric around the pool noodles (e.g. using ISDX and flexible components)? I notice you either didn't bother (totally understandable), or had some trouble with it yourself.
I tried to figure it out a few years ago, without good results. Fortunately, it's one of those things that doesn't usually make any difference, and is only worth it because it looks good.
Unread 25-06-2011, 06:09
We didn't spend much time on the bumpers. No plywood, no brackets, they're too shiny. Maybe a good pre-season project for the students in the fall.
