Go to Post This year may be one of the first years where there is a drastic difference in Regional level and Championship level strategies that drive robot design. - tim-tim [more]
Unread 23-06-2011, 22:05
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Crio Not Taking Code (Different Problem)
We download the C++ program to the robot and reboot it with the clam. When it turns back on the robot shows no code
Unread 27-06-2011, 20:20
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
When you say "Download" are you referring to the "FIRST Deploy" menu or are you talking about running or debugging your application through the "Remote Systems" debugger connection?
Have you checked the console? Is the FRC_UserProgram.out ending up on the cRIO in /ni-rt/system/ as expected?
