Go to Post In FIRST, you can either have comfortable safety margins or you can have a competitive robot, you can't have both. - Joe Johnson [more]
Unread 24-06-2011, 21:25
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
PSoc Java code.
Hello all,
Working on getting the PSoC IO to work with our switches.
After flashing and wiring it, it shows up in the Driver station fine.
But what do you use to make it work in code (JAVA)?
Just some short sample code will be greatly appreciated.
Thanks you.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 24-06-2011, 22:21
Jeremy Germita's Avatar
Jeremy Germita Jeremy Germita is offline
Co-Advisor/Lead Engineering Mentor
AKA: wood is good. plastic is fantastic.
FRC #5012 (Gryffingear) / (Antelope Valley FIRST Teams)
Jeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond reputeJeremy Germita has a reputation beyond repute
Re: PSoc Java code.
A simple snippet to read a digital input:
    DriverStationEnhancedIO m_io = DriverStation.getInstance().getEnhancedIO();
     * Get the state of a digital input
     * @param which The channel
     * @return The state of the digital input
    public boolean getDigital(int which) {
        try {                                         //You need to catch an exception
            return m_io.getDigital(which);    //Return the state of the digital input
        } catch(Exception e) {     //An exception will be thrown if the board is not plugged in
            e.printStackTrace();    //If an exception is thrown, print exception data
            return false;    //and return false
of course, you need your imports and all that other fun stuff.
Hope it helps
If you need help with anything else PSoC related, ask away. We've worked with all features of it in some form or another.
Drive Coach Team 5012 Gryffingear / Antelope Valley FIRST teams / EWCP - (2013 - Current)
Student / Driver / Programmer / CAD - FRC Team 399: Eagle Robotics / FTC Team 72: GarageBots - (2009 - 2013)
Los Angeles Region FTC FTA/CSA/Head Ref
[FF] FIRST Pick
2014 FTC Los Angeles Regional Compass Award Winner.
2017 - San Diego Regional / Sacramento Regional / Las Vegas Regional
2016 - Los Angeles Regional Creativity + Winners (1197, 987, 5012) / Las Vegas Regional Team Spirit + SF (5012, 5851, 5049) / Galileo Subdivision
2015 - Inland Empire QF (597, 5012, 4413) / Las Vegas Imagery + Winners (148, 987, 5012) / Newton Subdivision and World Champions (118, 1678, 1671, 5012)
2014 - Inland Empire Rookie All Star + Highest Rookie Seed + SF (2339, 1967, 5012) / Las Vegas Rookie All Star / Galileo Division Imagery
Unread 25-06-2011, 01:34
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
Hey thanks for the reply. I think we got it.
Also on a side note what happens when you feed a victor .set method with a value greater then 1? Does it just auto round down to 1?
Unread 25-06-2011, 09:35
Re: PSoc Java code.
This is the Victor.set(double speed) method:
     * Set the PWM value.
     * The PWM value is set using a range of -1.0 to 1.0, appropriately
     * scaling the value for the FPGA.
     * @param speed The speed value between -1.0 and 1.0 to set.
    public void set(double speed) {
        setSpeed(speed);
It calls this method from the PWM class:
     * Set the PWM value based on a speed.
     * This is intended to be used by speed controllers.
     * @pre SetMaxPositivePwm() called.
     * @pre SetMinPositivePwm() called.
     * @pre SetCenterPwm() called.
     * @pre SetMaxNegativePwm() called.
     * @pre SetMinNegativePwm() called.
     * @param speed The speed to set the speed controller between -1.0 and 1.0.
    final void setSpeed(double speed) {
       // clamp speed to be in the range 1.0 >= speed >= -1.0
        if (speed < -1.0) {
            speed = -1.0;
        } else if (speed > 1.0) {
            speed = 1.0;
        // calculate the desired output pwm value by scaling the speed appropriately
        int rawValue;
        if (speed == 0.0) {
            rawValue = getCenterPwm();
        } else if (speed > 0.0) {
            rawValue = (int) (speed * ((double)getPositiveScaleFactor()) +
                              ((double)getMinPositivePwm()) + 0.5);
        } else {
            rawValue = (int) (speed * ((double)getNegativeScaleFactor()) +
                              ((double)getMaxNegativePwm()) + 0.5);
        // send the computed pwm value to the FPGA
        setRaw(rawValue);
As you can see from the part I have colored green, it automatically clamps values from -1 to +1. Giving it any value lower or higher will set it to full speed reverse/forward.
-Jeremy
[FF] FIRST Pick
Unread 25-06-2011, 23:10
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
Cool Thank you.
Can't wait to test this out.
Unread 27-06-2011, 21:06
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
Update: After running the code netbeans gives this error.
[cRIO] edu.wpi.first.wpilibj.DriverStationEnhancedIO$Enha ncedIOException: Enhanced IO Missing
[cRIO] at edu.wpi.first.wpilibj.DriverStationEnhancedIO.getD igitals(DriverStationEnhancedIO.java:629)
[cRIO] at edu.wpi.first.wpilibj.DriverStationEnhancedIO.getD igital(DriverStationEnhancedIO.java:619)
[cRIO] at Test_bot_2011_v2.DriverStation_IO.getDigital(Drive rStation_IO.java:17)
[cRIO] at Test_bot_2011_v2.Test_Main.teleopPeriodic(Test_Mai n.java:28)
[cRIO] at edu.wpi.first.wpilibj.IterativeRobot.startCompetit ion(IterativeRobot.java:141)
[cRIO] at edu.wpi.first.wpilibj.RobotBase.startApp(RobotBase .java:154)
[cRIO] in virtual method #10 of javax.microedition.midlet.MIDlet(bci=17)
[cRIO] at javax.microedition.midlet.MIDletTunnelImpl.callSta rtApp(64)
[cRIO] at com.sun.squawk.imp.MIDletMainWrapper.main(110)
[cRIO] in virtual method #95 of com.sun.squawk.Klass(bci=25)
[cRIO] at com.sun.squawk.Isolate.run(1506)
[cRIO] at java.lang.Thread.run(231)
[cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
Any ideas? I have all the imports and it complies fine.
Unread 27-06-2011, 21:15
Re: PSoc Java code.
That usually means it is not plugged in.
Does the driverstation program show a green light indicator on the "IO" tab?
Go into diagnostics and look at a similar indicator next to IO.
Another possible cause is that you have flashed the PSoC with incorrect firmware. Make sure you flashed it with the most up to date FRC firmware, not the stock firmware.
[FF] FIRST Pick
Unread 27-06-2011, 21:24
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
Yeah the PSoC is plugged in with a switch, and it shows up and works fine in the driver station I/O Tab.
Unread 27-06-2011, 21:28
Re: PSoc Java code.
Strange....
Can you post screenshots of the driverstation(in the diagnostics and IO tabs) and your code?
A full log(from cRio boot to where the exception is thrown) would be helpful to see.
[FF] FIRST Pick
Unread 27-06-2011, 22:28
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
[cRIO] WDB Comm Type: WDB_COMM_END
[cRIO] WDB: Ready.
[cRIO]
[cRIO] Leaving debug.o StartupLibraryInit
[cRIO] * Loading StartupDlls: NiRioRpc
[cRIO] * Loading StartupDlls: niorbs
[cRIO] * Loading StartupDlls: NiViSrvr
[cRIO] * Loading StartupDlls: visa32
[cRIO] * Loading StartupDlls: nivissvc
[cRIO] task 0xed0cd8 (PAL00fa2090) deleted: errno=0 (0) status=0 (0)
[cRIO] NI-RIO Server 3.2 started successfully.
[cRIO] task 0xc4c168 (NiRioRpc) deleted: errno=0 (0) status=0 (0)
[cRIO] * Loading StartupDlls: nivision
[cRIO] * Loading StartupDlls: niserial
[cRIO] * Loading StartupDlls: FRC_FPGA
[cRIO] * Loading StartupDlls: FRC_NetworkCommunication
[cRIO] task 0x1af55b8 (t2) deleted: errno=0 (0) status=0 (0)
[cRIO] FRC_NetworkCommunication was compiled from SVN revision 2258
[cRIO]
[cRIO] NI-VISA Server 4.5 started successfully.
[cRIO] task 0xe4f308 (t1) deleted: errno=1835009 (0x1c0001) status=1 (0x1)
[cRIO] FPGA Hardware GUID: 0x2EAA5E59CAF1A8A966853A011B61CC91
[cRIO] FPGA Software GUID: 0x2EAA5E59CAF1A8A966853A011B61CC91
[cRIO] FPGA Hardware Version: 2011
[cRIO] FPGA Software Version: 2011
[cRIO] FPGA Hardware Revision: 1.5.3
[cRIO] FPGA Software Revision: 1.5.3
[cRIO] * Loading StartupDlls: FRC_JavaVM
[cRIO]
[cRIO]
[cRIO] [OTA Server] Version: 2011 FRC, Jan 6 2011, 09:47:42
[cRIO]
[cRIO]
[cRIO] Welcome to LabVIEW Real-Time 8.6.1f3
[cRIO]
[cRIO] [Squawk VM] Version: 2011 FRC, Feb 18 2011, 15:57:21
[cRIO] FPGA Hardware GUID: 0x2eaa5e59caf1a8a966853a011b61cc91
[cRIO] FPGA Software GUID: 0x2eaa5e59caf1a8a966853a011b61cc91
[cRIO] Default IterativeRobot.disabledInit() method... Overload me!
[cRIO] Default IterativeRobot.disabledContinuous() method... Overload me!
[cRIO] Default IterativeRobot.disabledPeriodic() method... Overload me!
[cRIO] task 0x21cfd38 (FTP Server Connection Thread) deleted: errno=70 (0x46) status=0 (0)
[cRIO] Default IterativeRobot.teleopInit() method... Overload me!
[cRIO] at Test_bot_2011_v2.Control_Drive.stick_drive(Control _Drive.java:56)
[cRIO] at Test_bot_2011_v2.Test_Main.teleopPeriodic(Test_Mai n.java:26)
Here you go.
Also do you know how to kill the robot program within code?
Unread 29-06-2011, 06:08
Re: PSoc Java code.
I don't see anything out of the ordinary in this log. (Except for the exception.)
I can only tell you it is most likely a hardware issue. Try playing around with different cables, ports and hubs for the PSoC board. Again, verify that it is the most up to date firmware.
There is no way to put the robot into the disabled mode from the code. you could however, stop running normal teleop/autonomous code using a simple boolean input.
You could put logic like this into your loops:
if(!disabled) {
  //Teleop Code here!
} else {
  System.out.println("Teleop Code Not Running");
Why exactly do you need to disable it from code?
[FF] FIRST Pick
Unread 06-07-2011, 21:00
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
What is the most up to date firmware on the PSoC?
I think I am running v20.
I was thinking using the disable mode to kill the robot when it crosses over the line (with line sensors) as a safety feature.
The PSoC shows up in the Driverstation I/O fine but still gives me the expectation in console.
Unread 07-07-2011, 00:51
Mk.32's Avatar
AKA: Mark
Re: PSoc Java code.
Nvm. I just got it to work.
Lol, Under config enchanted has to be checked. x]
Thanks for the help.
Unread 20-07-2011, 12:28
Kevin Wang's Avatar
Kevin Wang Kevin Wang is offline
Software Engineer, Webmaster
FRC #0694 (StuyPulse)
Kevin Wang is an unknown quantity at this point
Re: PSoc Java code.
Enhanced, not enchanted.
Also, for anyone who's interested, here's a link to my team's PSoC code for this year:
https://github.com/prog694/frc/blob/...Interface.java
