Go to Post Baker, you certainly are a trouble maker. :) - Rich Kressly [more]
Unread 24-06-2011, 01:07
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Best of: Polycarbonate
Originally Posted by Laaba 80 View Post
We dont use metal for structural parts, the frame is entirely polycarb. If we have an option to make a piece out of plastic, or even better, clear plastic, we do it.
www.chiefdelphi.com/media/photos/34998
If you look closely, you'll notice we even made clear wheels.
Aside from our great resources to work with plastics, we also do it because it is cool. It has always been a goal to be as clear as possible, and our robots have become clearer every year. If you ever get a chance to visit our pits, you will also see the clear isnt limited to the robot, we have clear toolboxes, as well as an awesome clear battery charging station
It is nice to see some transparency in a group for once. Seriously though, thanks for explaining it to me. I've heard arguments by teams that argue for all wood robots and thought motives might be similar. Turns out they are completely different.
Sorry if the pun was too bad, I couldn't resist.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 24-06-2011, 10:06
Mike Wittman's Avatar
Mike Wittman Mike Wittman is offline
Plastic Man
FRC #1714 (More Robotics)
Mike Wittman is an unknown quantity at this point
On this robot we also made clear sprockets and a clear ratchet gear for the kicker. One day I would like to see us try to make a clear transmission, gears and all. We took the first step with this robot. We used an AndyMark 2 speed transmission, removed the metal side plates and made clear ones.
Mike
Tie two birds together, though they have four wings they cannot fly
www.morerobotics.org
Learn More, Give More, Be More
Unread 25-06-2011, 23:52
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Originally Posted by jwfoss View Post
Seems as though 190 has a long history of using polycarb...
That we do, polycarbonate is used for major features on almost every one of our robots. The 2003 robot deserves to be added to the list of cool polycarbonate features.
As does 2007 (some of you may be very confused at this mention). By far the most recognizable feature of the Goat-Dactyl were the giant sheet-metal ramps, but one of the most important features on them were the almost invisible anti-rollback devices. You can see one just above the painted numbers, and they served to keep our partners above 4" in the event that the ramps didn't lift properly or in time. We relied on the toughness of the material to survive repeated robot impacts and the many many cycles of use.
We also used the insulating properties of the material to house the custom high-power slip ring at the base of the turret in 2008.
2011 used polycarbonate wings as an alignment device for the tower base. Because they extended well beyond the frame perimeter when deployed, not only were they designed to align the robot in a full-speed (12fps) collision with the tower, but they also had to withstand the force of a worst-case collision with another robot. Polycarbonate was the only material both light enough and tough enough for the job.
It's a wonderful engineering material for it's toughness and machinability. Unlike aluminum or steel, polycarbonate will deflect elastically to absorb the energy, which means it will return to it's original shape. This is great in applications that are likely to see high impact forces, since it will not dent or kink permanently under forces that would do the same to aluminum.
Unread 26-06-2011, 00:31
Stephi Rae's Avatar
Stephi Rae Stephi Rae is offline
Lets play robots!
AKA: Stephanie Morrison
Stephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to behold
Send a message via AIM to Stephi Rae
Additionally 190's 2011 robot had a polycarbonate claw, both the structure/sides and the pulleys for the pulleys for the polycord. The minibot was also entirely polycarb. But both of these uses were pretty common this year.
2k7 had a polycarb claw, also.
~Stephanie Morrison (Hoag)~
Student - Team 1983 (2007-2008)
Mentor - Team 190 (2009-2012)
Mentor - Team 1983 (2013-2014)
Mentor - Team 1318 (2015)
Coach - Apex Robotics 5803 (2016-Present)
Unread 26-06-2011, 12:53
Chris is me's Avatar
AKA: Pinecone
It's certainly a cool material. I've considered using it in many places that teams use sheet metal now, since you can get it thicker for the same weight and it deflects under load (elasticity). If you need it to be more solid you just add a flange.
I've been meaning to CAD a polycarbonate drivetrain lately. You might see it in a few days.
Unread 26-06-2011, 13:23
Joining the 900 Meme Team
FRC #0079
Take a look at 703. I know their 2007 DT has some good pictures up here. They use a polycarb DT every year it seems. It is pretty but it is really thick stuff.
Unread 26-06-2011, 13:52
Wait. See a polycarbonate drivetrain? (Highlight the blank.)
Actually, one of the best uses of polycarb has to be this little gem. Even though it isn't used on a robot necessarily...
Unread 27-06-2011, 18:59
Nuttyman54's Avatar
Mentor, Tactician
One word of warning on the PC drivetrain is that because of the elastic deflection, large hits have a tendency to throw the chain if you're not careful with your construction. This was a serious problem on our 2003 and 2006 robots (mentioned above). Our 2006 drive team considered it a miracle if the robot made it through a match with all the chains still on.
Unread 27-06-2011, 20:10
AKA: Pinecone
Always a big problem. You really have to overbuild a polycarbonate chassis to make it take those hits effectively.
Though in the advent of bumpers, this has been less of an issue.
Unread 05-07-2011, 01:23
Molten's Avatar
AKA: Jason
Reported.
