Go to Post At every event I've seen this year, there has been at least one robot that left a part on the field. Even some of the robots have decided they don't want to play and this year and made a break for it in autonomous! :yikes: - ctt956 [more]
Unread 27-06-2011, 22:07
Re: Non-volatile memory?
Originally Posted by Jared341 View Post
Joe,
Do you have a ballpark figure of what this number tends to be? We have, in the past, written logger classes that make several writes to "disk" per second. Sounds like a longer buffer might be in order to preserve our cRIOs...
Typical flash memories are on the order of 100,000 to 1 million writes. I'm not sure if the cRIO does wear leveling, but that could extend it by another order of magnitude or more.
Unread 28-06-2011, 12:24
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
The cRIO uses a disk-on-chip from M-Systems (the M-DOC G4)... it does wear leveling internally.
-Joe
