Go to Post I've never encountered a motor as forgiving as a CIM - Stall them for 20 seconds, run them hot on a short turnaround, or call them mean names in between matches and they'll just keep doing their thing. - thefro526 [more]
Unread 08-02-2011, 21:55
CapnKernul CapnKernul is offline
FRC #1515
CapnKernul is an unknown quantity at this point
Non-volatile memory?
I was looking through the Javadocs and couldn't find any class that mentions non-volatile memory on the robot. I'm not even sure if the cRIO has a filesystem that the user programs can access.
Anyone know if there's any way for a robot Java program to read and write values to any form of non-volatile memory?
Unread 09-02-2011, 00:09
Re: Non-volatile memory?
Look at the FileConnection class. Use Connector to get a FileConnection.
this may help
Unread 09-02-2011, 14:24
FRC #1515
Awesome, thank you!
Unread 21-05-2011, 20:11
mdrouillard mdrouillard is offline
FRC #0772
mdrouillard is an unknown quantity at this point
As I am not too familiar with Java but am trying to do file io to the crio's non-volatile memory using C++. In the 2011 wplib I simply do not see an equivalent class as fileconnector, as suggested by Ron in the Java suggestion. Therefore does anyone have sample code that could write something to the crio in c++ . Perhaps I simply need to include stdio.h or a basic library, but then I must as the question of whether writing to the filesystem is allowed or if there are certain FRC restrictions on methods regarding this.
Thanks to, and thoughts from everyone are welcomed.
Michael
Unread 23-05-2011, 03:05
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Michael
In C++ you can use the typical file i/o library functions to access the disk. There are no limitations related to FRC. It is a flash disk, though, so very high numbers of writes will damage the flash.
-Joe
Unread 25-06-2011, 15:32
Jared Russell's Avatar
Taking a year (mostly) off
-Joe
Joe,
Do you have a ballpark figure of what this number tends to be? We have, in the past, written logger classes that make several writes to "disk" per second. Sounds like a longer buffer might be in order to preserve our cRIOs...
Thanks.
Unread 27-06-2011, 22:07
Originally Posted by Jared341 View Post
Joe,
Typical flash memories are on the order of 100,000 to 1 million writes. I'm not sure if the cRIO does wear leveling, but that could extend it by another order of magnitude or more.
Unread 28-06-2011, 12:24
The cRIO uses a disk-on-chip from M-Systems (the M-DOC G4)... it does wear leveling internally.
-Joe
