Go to Post ...playing hard and impressing teams is way more valuable than trying to play god with the rankings. - JamesBrown [more]
Unread 28-06-2011, 08:10
johncap100 johncap100 is offline
FTC #0658
johncap100 is an unknown quantity at this point
Java and Mechanum
Wondering if anyone has experience with Java and programming a bot using mechanum wheels. we have downloaded some code but it appears that as soon as we click enable in either teleop or autonomous all four wheels start to move. When we move the joystick there is very little contgrol, certainly not enough to control the robot on the ground.( it is elevated off ground right now) THanks
Unread 28-06-2011, 10:00
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Java and Mechanum
http://code.google.com/p/runnymede-r...0_Team_1310_V2
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 28-06-2011, 16:17
FTC #0658
Thank you for the site, but where is it on the site
thanks
Unread 28-06-2011, 23:22
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Dustin Shadbolt is on a distinguished road
thanks
I haven't looked at the code, but just at the site briefly. Most likely it will be under MyRobot.CPP. Just load it up and press control+f and type in "Mecanum".
~DShad
Unread 01-07-2011, 00:56
AKA: Mr. Lim
My apologies. The code from Team 1310 is C++, but hopefully you will find a use for it.
The code of interest will be in MyRobot.cpp, where most of the heavy-lifting is done with respect to Mecanum.
It uses US Digital encoders in an AndyMark Toughbox at all for corners of the robot. A velocity based PID ensures all the wheel are spinning at the correct speeds.
The math does conversions such that all velocities are in metres/second.
The mecanum algorithms are based on a presentation that Ian Mackenzie from 1114 did on holonomic drives back in 2004.
Unread 19-07-2011, 07:20
reported
