Go to Post People do amazing things for stuff the have a passion for. - Foster [more]
Unread 02-07-2011, 11:27
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
pic: Pigmice Northwest Drive
Unread 02-07-2011, 11:30
Andrew Lawrence
Posts: n/a
Re: pic: Pigmice Northwest Drive
Looks good! Only question I have is you called it "Northwest Drive". Is this any different from West Coast Drive? If so, what are the differences and advantages/disadvantages? I'm assuming the duel omnis on the corners are for ease of turning, and that there is no drop on the center wheel because of that.
Unread 02-07-2011, 15:11
This chain-path is on the outside of the frame rails. Traditional WCD has an inside chain-path. This also doesn't look like it has the characteristic bearing blocks of a real WCD.
Unread 02-07-2011, 23:43
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Just curious, why the 4 inch wheels? The smallest I've heard of in the past are 6 inches. Also, don't be nervous about posting stuff on here. It looks really good and you should be proud of your work. We may ask questions, but we try not to be too scary.
Jason
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 02-07-2011, 23:59
NickE's Avatar
NickE NickE is offline
_
254 used 3.5" this year and 233's wheels were smaller. In recent years, small wheels have been one of the defining features of "west coast drive" robots such as this. Just look at the robots of two of the current world champions.
Unread 03-07-2011, 00:04
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
bout 2.75in rims on the corners last year.
next year expect possibly 2.5in rims for packaging reasons.
Unread 03-07-2011, 00:06
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
I do believe that there have been WCD robots with the chain in both locations and even a few wit it inside of the frame rail. The real distigushing feature here is that this robot has omni-corners and no drop on the center wheel. ALL true west coast drives have droped center wheels and none use omniwheels.
Unread 03-07-2011, 03:23
Molten's Avatar
AKA: Jason
Why though? What is the functional advantage?
Jason
Unread 03-07-2011, 03:43
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Jason
-Less Weight
-Cheaper Material
-Less Machine Time
-Less Gearing, 233 may get away with only one stage of gearing?
-Better acceleration
-More efficient.
-RC
R.C.
MadTown Robotics Team 1323
Unread 03-07-2011, 18:01
AKA: Alan Wells
FRC #1350 (Rambots)
Jason
Less, and thus lighter, gearing results in the same effective ratio, also the wheels are smaller. the weight savings might be enough of a reason, but smaller wheels and the associated gearing allow the motors to operate at a different, possibly more efficient part of the performance curves.
Unread 03-07-2011, 18:36
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
That is not strictly true. While at the same rpm the smaller wheels would go at a different (slower) speed, the gear ratio could be used to compensate. While there are fewer gears necessary to get the same speed,there isn't a change in the fact that, with enough gears, you can gear for any speed
Unread 03-07-2011, 18:41
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
I like it, but how are you attach your SS? and why did you make a "V" in front instead of adding a front rail because the rules for the bumpers this year would not allow that. How exactly are you planning to mount the bumpers to the 1' alum. tubing on the sides? and do I spy a custom center wheel? last question I promise, hex axle or keyed axle?
But looks great keep up the good work
Unread 03-07-2011, 18:51
There is no single distinguishing feature for a real WCD IMO, I only consider 254 based drives to be real WCDs.
Unread 03-07-2011, 20:53
Molten's Avatar
AKA: Jason
Thanks for the responses. I knew there was a good reason just couldn't figure it out. I still have my reservations about such small wheels, but that is probably just because they are new to me.
Jason
Unread 03-07-2011, 20:57
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
I've been thinking of a similar design, but I was planning on using 4 plaction wheels in the center with the 4 omnis in the corners. I believed this would help increase stability from being spun by other robots.
8 wheel - 4 plaction center, 4 omni corners for stability and forward pushing. No drop.
Anybody think the 4 wheel center would actually do anything to fight being spun from other robots pushing your corners?
