Go to Post Remember, there are many differents path to obtaining knowledge. There's no need to pigeonhole the process. - Karthik [more]
Unread 03-07-2011, 22:39
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Robots in hometown parades
How common is putting the robotics teams in parades?
In the Albert Lea, MN parade earlier today both Albert Lea HS Catalyst (3633) and Alden-Conger Knights (2957) had floats with the robot driving on the road. 2957 made no modifications, but 3633 whipped up a pneumatic candy-cannon in a few days and used it with great results. We plan to have pictures and video of the event.
So, did your team participate in a parade, and if so, to what extent?
Unread 03-07-2011, 22:46
ttldomination's Avatar
Sunny
Re: Robots in hometown parades
Back in the day, when the team carried itself with a bit more enthusiasm, we used to take part in the two local fall parades. They were awesome, but I would recommend choosing robots carefully.
For one year, we demoed the '07 robot. Wasn't very cool when you consider that the game was similar to the 2011 game, and the most we could do was raise the elevator up and down.
But the next year, we demoed our '08 robot (the one that shot the big red balls). That was HUGE with the crowd, and we met huge cheers all the way down the route.
So I would think it's common enough, just make sure to have something to please.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 03-07-2011, 23:22
Billfred's Avatar
Billfred Billfred is offline
1293 ran their 2005 robot in some parades that year. Some advice:
1) If your robot is done with competitions, consider pneumatic tires. Converting to them saved us a bit of wear and tear on the rest of the robot.
2) If you're still competing, a trick Don Rotolo mentioned involved wrapping your wheels in painter's tape, then duct tape. Similar effect, but it saves your wheels from the damage of the road.
3) Think of how you're going to handle batteries. 1293 modified their robot to add a tray to hold an extra three or four--just disconnect the dead one, plug in the new one, and roll on. (This was in the days of the IFI controller, where connections were made in seconds rather than minutes.)
4) Think of how you're going to drive it. Do you have a trailer to operate your driver station on? Hard to juggle joysticks and a classmate if you're just walking.
5) Think of how you're going to handle the robot if it dies mid-route. This happened to 1293 in the Irmo Okra Strut parade when a set screw backed out, and led to me pushing probably close to 175 pounds of robot and extra batteries a good half-mile to the finish. Be able to load it on a trailer if it fails, or draft a linebacker from your school's football team for the parade just in case.
I think they've done a couple of parades since, but I don't know the specifics (I stopped working with them full-time after the following FRC season, but still keep in touch).
Unread 03-07-2011, 23:28
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
On that point, could you wire multiple batteries in parallel to increase the battery life?
Unread 03-07-2011, 23:54
NickE's Avatar
NickE NickE is offline
_
If you're looking to modify an old robot for use in PR events and parades, I'd recommend the VEX Controller. It works great, is very simple and connects almost instantly. Furthermore, the controller is completely handheld and doesn't require any external power source (a big advantage for parades). There is potential for interference when using the crystals (we've only had issues with other VEX robots around using the same frequency), but these issues seem to be gone when using VEXnet which typically connects in ~10 seconds. Our t-shirt cannon Shockwave and 2009 robot Devastator, two of our popular PR robots are both running VEX controllers with very simple code.
Unread 03-07-2011, 23:56
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
2614 runs in 3 or 4 parades a year.
We modified our 2009 bot to dump candy, and it is controlled by a driver on foot with a backpack carrying the 2009 control system.
Up to three more bots are controlled out of the back of a leading truck that also carries candy refills and batteries. In a dead robot situation, we can load it up into the truck.
Tomorrow, we'll be running 4 robots.
Unread 04-07-2011, 00:03
RayTurner1126's Avatar
RayTurner1126 RayTurner1126 is offline
team co-lead, mechanical lead
FRC #1126 (SparX)
RayTurner1126 will become famous soon enoughRayTurner1126 will become famous soon enough
1126 participated in a parade this past saturday with 1511. 1511 had it hink 2 of their robots driving on the ground, and another 3 on their float. we (1126) had a robot in a small trailer just big enough to turn around on, and we had out posts and repeatedly made logos for the crowd on the pegs (we only had bottom and middle up)
we are also participating in another parade next week, we plan to do the same
we also duct taped an american flag to our alignment spear and had it "wave" to the crowd
What time is it?? 11:26!!!
Go SparX on 3!!!
Unread 04-07-2011, 00:14
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
This year we took our old (and partly torn apart for parts) 2009 robot to one of our towns Mardi Gras parades. We are from Louisiana, there are several parades a week in February and March, not even getting into the New Orleans ones. Since it was on short notice and during one of the last weeks of build season, we just put the robot in the back of my-car-turned-ghetto-Mardi-Gras-float. Although he didn't run, people still liked seeing a robot covered in beads. We think we are going to do it next year (with way more beads because people are crazy about it) but I am a little worried about driving a robot down a 5 mile Mardi Gras parade route.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 04-07-2011, 01:05
Andrew Lawrence
Posts: n/a
Each year team 256 parades one or two of its robots in the Homecoming Parade throughout downtown Willow Glen. A ton of people love it, and we end up getting a lot of people interested in robotics. After the parade we go down Lincoln Avenue (downtown) and let interested people try out the robots. We usually have 2 robots out there, our t-shirt robot where we fire t-shirts to people, and our competition robot for that year, unless there's not much to show off, like previously mentioned.
Unread 04-07-2011, 01:18
tommy0019's Avatar
tommy0019 tommy0019 is offline
FRC #2957
tommy0019 is an unknown quantity at this point
Team 2957 had one modification, the american flag that flew on the top of the arm
Unread 04-07-2011, 04:29
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We've done the local parade two years in a row now (won the Grand Marshall trophy both years.)
We put 3 old competion robot on a trailer and have some VEX robots to drive around. This year we made a custom robot shaped like a doghouse (we're the Swartdogs.) The doghouse robot was a big hit with the crowd. We used two batteries in parallel and made it through the entire parade - it was about 45 minutes drive time I believe.
In the afternoon we do a demo for 2 hours driving last year's competion robot. Overall, it's a really good event for us.
Unread 04-07-2011, 08:23
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We (33) participated in a Rochester Chhristmas Parade last fall (erm... winter? it was freezing outside) along with teams 1, 201, and 245 (Juggernauts, FEDS, and Adambots respectively).
http://www.chiefdelphi.com/media/photos/36014
We borrowed a truck from Chrysler, and decorated it. The parade required all floats to follow a "candy land" theme for the parade, hence the candy. We used our 2007 robot, 201 and 245 (on the other side of the honeycomb wall) used their 2009 robots and exchanged balls between them. The robot in the picture is limp because it is turned off, but it waved the FIRST tube around well once we turned it on (we also tried to get it to throw a tube, but the tube just fell).
We won First Place in the high school/college category.
Kettering Motorsports
Unread 04-07-2011, 21:18
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
Team 166 just participated in Merrimack's parade - we didn't run it during, but we ran it before at the pancake breakfast. I don't really know what happened, I was serving strawberries in the kitchen, but I saw quite a crowd there!
During the parade, we had the robot posed with a tube traveling in the back of a trailer. In past years, though, we've had our infamous grillbot follow the parade.
GSR Dean's List Finalist 2011
Unread 05-07-2011, 11:33
princessnatalie's Avatar
princessnatalie princessnatalie is offline
AKA: Natalie
FRC #2471 (Team Mean Machine)
princessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud ofprincessnatalie has much to be proud of
Team 2471 participates in their town parade every year. We also have a festival afterward, where we set up games for people to play with our robot. This year it is a timed trial with an obstacle course and the deploying of our minibot.
We build a new robot for the parade, our "MascBot" which is made for our highschools mascot costume to go on it. Last year the parade and festival them was "Wizards" or something, and we made the arms of the mascot spin and the head rise up and down. We actually won second place in the walking float division.
We are from a really small town, and are thinking about being in bigger town parades, specifically the Portland parades that I have never seen our Portland teams be apart of.
Seattle Cascade Regional Champions
thanks 2046 and 492
Autodesk Oregon Regional
2011 Seattle Cascade Regional Champions
thanks 1510 & 2660
2011 Autodesk Oregon Regional Champions
thanks 360 & 3711
Unread 05-07-2011, 12:48
Jack Murphy Jack Murphy is offline
Jack Murphy is just really niceJack Murphy is just really niceJack Murphy is just really niceJack Murphy is just really niceJack Murphy is just really nice
Y'all got me reminiscing now...
I stood with my 4th grade son as we watched the local robotics team drive down Main Street on the Fourth of July.
They handed him a flyer that announced that there would be a chance to see the robot in the park after the parade.
He looked up at me and said "Dad? Can we check that out?"
(he said that a lot but that's to many tales to tell here)
Fast forward.
Georgia Dome!
WORLD CHAMP!
That same little boy (to me) on the drive team. Up there with Dean and Dr. Flowers.
Yup! Parades are good.
My Heart is my favorite Part
