Go to Post Billfred = genius - rsisk [more]
Unread 03-07-2011, 21:14
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: Pigmice Northwest Drive
Originally Posted by Colin P View Post
I've been thinking of a similar design, but I was planning on using 4 plaction wheels in the center with the 4 omnis in the corners. I believed this would help increase stability from being spun by other robots.
8 wheel - 4 plaction center, 4 omni corners for stability and forward pushing. No drop.
Anybody think the 4 wheel center would actually do anything to fight being spun from other robots pushing your corners?
Highly doubt it. You'll still get spun easily. If you want traction and maneuverabilit take a look at 148/217 2010 setup.
-RC
R.C.
MadTown Robotics Team 1323
Unread 04-07-2011, 13:54
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Many times it has been said that you shouldn't bother shifting if you are gonna have omni wheels. It's fairly accurate. You can do the math if you like, but it will be easier to spin the wheels and you won't win many pushing contests.
One other note: Low gear is defintely too slow. This past year we ran a similar speed w/ 13fps and 3.5fps. In low gear we could push without issues, but it took a very long time to get anywhere. It really wasn't worth it. Try gearing your low gear closer to the traction break point. Which will probably comeout to be 7-8fps.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 04-07-2011, 14:45
AdamHeard's Avatar
Lead Mentor
When you're driving around trying to get to places, shouldn't you always be in high gear?
I know our driver stayed in our 17fps high gear 90% of the match, if not more.
Unread 04-07-2011, 14:53
AdamHeard's Avatar
Lead Mentor
Originally Posted by Molten View Post
Thanks for the responses. I knew there was a good reason just couldn't figure it out. I still have my reservations about such small wheels, but that is probably just because they are new to me.
Jason
This post I made in another thread (and some other posts from others in that thread) describe more benefits of small wheels.
http://www.chiefdelphi.com/forums/sh...6&postcount=74
Unread 04-07-2011, 15:01
NickE's Avatar
NickE NickE is offline
_
Agreed. I could probably count the number of times we used low gear in 2011 on one hand. Low gear is one of those things that is rarely needed in everyday match play. However, when we need it, we really need it. You can probably make low gear faster than 3.6 ft/sec, just make sure it's traction limited.
Unread 04-07-2011, 15:17
AdamHeard's Avatar
Lead Mentor
The issue here is he's stuck with the AM stock gearing. So he can't independantly vary the speeds.
However, I do feel 13.5s is a bit slow for most games, 15-16 is much nicer.
Unread 05-07-2011, 09:08
Brandon Holley's Avatar
Free speed? Or under theoretical load?
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
