Go to Post The robot is talking to you, you must listen to find out what might be wrong. - Al Skierkiewicz [more]
Unread 05-07-2011, 09:27
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: 5" Wheels
Originally Posted by Brandon Holley View Post
Stogi and Adam-
Are you sure about the Colsons having less traction than a wedgetop/roughtop??
A member of our team did a ton of wheel traction testing as part of his capstone project...the results may surprise you guys.
-Brando
Also during matches they tend to heat up. Making the rubber sticky and more traction. They also wear down pretty evenly.
Unread 05-07-2011, 11:49
Andrew Lawrence
Posts: n/a
Re: 5" Wheels
WOAH! 5 inch wheels???!!! It's like the compactness of a 4 inch wheel, and the largeness of a 6 inch wheel! Amazing!
I googled 5 inch wheels, and found some good results.
Unread 05-07-2011, 12:00
Aren Siekmeier's Avatar
on walkabout
Re: 5" Wheels
If you're looking for a more customized wheel to suit your needs, and you have any crude lathing or milling abilities, you could consider making your own out of stock aluminum. Then you can make the diameter whatever you want, as well as customize other features like lightening pattern and how it fastens to sprockets and/or shafts.
Obviously, you should CAD the thing first, keeping in mind the limitations of whatever shop tools you have. Then, the actual machining process would be an excellent exercise for any student. We really need to give our students more jobs like this; they somehow can't ever drill a hole in the right spot, let alone mill something to spec.
Sorry if that was too unrelated to your inquest about buying wheels, but its an option that, while usually not as practical, shouldn't be totally ignored.
