Go to Post Besides, if you look back on anything you've already made and can't find any flaws that can be improved, you're doing it wrong. - artdutra04 [more]
Unread 05-07-2011, 18:34
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: What happens when a bored EE gets ahold of 57,600 LEDs
A few half answers: It uses all custom circuitry. I think he said it has a couple DSPs to process the video. The video input is just a normal yellow RCA jack for composite video. Resolution is 160x120. He said it gets warm..... It's powered by a few lithium battery packs, one plan is to install them in some shoes!
He's been working on this project for a few months. It's been fun watching the progress, and the design changes as he figured things out. The flex circuit boards are expensive, and that many LEDs are expensive.
Unread 05-07-2011, 22:21
nixiebunny nixiebunny is offline
AKA: David Forbes
FRC #4183 (Bit Buckets)
nixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond reputenixiebunny has a reputation beyond repute
What he said! It gets warm because it's a polyester lab coat with another layer of plastic insulation. The whole thing dissipates 100 W, which is about 20 milliwatts per square inch.
I wrote a bunch of VHDL code to convert digitized video to RGB pulse width modulation for the LEDs. It works just like the billboards, but thinner.
I wouldn't mind spraying some conformal coating on it to make it water resistant. I'll have to ask my friend who works at an LED billboard company for recommended products.
Unread 05-07-2011, 22:24
Well, there is always quantity pricing. Based on my experience with LED lighting wall panels, they do get hot after a while. In addition, the scanning of the array produces horrendous RF near the panel. Keep mics away from the panel and the wiring.
A few years ago, I was walking the floor at a component exposition and turned the corner to face an LED manufacturer's display. I could feel the heat from about ten feet away. The display was all of their products mounted on a single panel about six foot high and two to three foot wide. I think it was ledtronix.
Unread 06-07-2011, 04:14
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
What size LEDs are being used? (I remember, about 5 years ago, there were SMT LEDs available in sizes as small as roughly 0.5 mm × 0.8 mm × 1.2 mm, or multicolour ones in 4.0 mm × 4.0 mm × 2.5 mm packages. I think Osram Sylvania was the manufacturer I'd used.)
I'm also pleasantly impressed by the fact that someone is putting all those Arduino-based units of clothing to shame. (There are a few genuinely innovative ones, but for the most part, the novelty of a string of flashing lights in a jacket wore off a couple of years ago. Making it into a TV raises the bar.)
Unread 07-07-2011, 15:47
AKA: David Forbes
The LEDs are the standard 0603 size, 1.6mm x 0.8mm. They are made by Kingbright, and come on reels. I bought 22,000 of each of R,G and B types. Surprisingly, green costs twice as much as blue.
This display runs at much lower power than a typical LED billboard, since it's designed for use indoors or at night. Curiously, the idle current of the 1,000 driver chips (15mA at 3.3V) uses as much power as the LEDs themselves.
Unread 07-07-2011, 18:08
DonRotolo's Avatar
Back to humble
FRC #0832
OMG that is awesome! Although the phrase "too much time on your hands" comes to mind...
Now to connect video cameras that show the scene 180 degrees from the LED, making an effective invisibility cloak lab apron.
Unread 07-07-2011, 19:02
billbo911's Avatar
billbo911 billbo911 is online now
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
3 to 4 cameras and a little video processing ought to do the trick.
Unread 07-07-2011, 21:11
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
This is definitely one of the coolest things I have seen recently.
The Lampduino I am building pales in comparison. I have a measly 8x8 grid!
Team 2052- KnightKrawler
Mentor and volunteer
Unread 08-07-2011, 11:44
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
So.... I want to write something snarky about the suit Will-I-Am wore at the World Championship, but I'm fighting the urge.
Perhaps next year's championship's entertainment should feature Squirrel's brother?
Blake
Unread 11-07-2011, 23:01
MrForbes's Avatar
AKA: Jim
A little update on his web page
http://www.cathodecorner.com/videocoat/
Unread 12-07-2011, 09:42
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
That is awesome! Kinda makes me want to have one..
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 13-07-2011, 15:47
AKA: Bryan
Heard about it again on the radio yesterday (the hosts called it "nerd cool"), and it is featured on Engadget today!
http://www.engadget.com/2011/07/13/w...s-for-burning/
Unread 13-07-2011, 15:52
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
That cost 20 grand to make! Oh my...
