Go to Post When you get a vanity license plate with you team or robot name on it or some other FIRST reference. - Raul [more]
Unread 06-07-2011, 19:58
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: pic: Render Test - Robot Funhouse
Originally Posted by MattC9 View Post
I think 148 should chrome there robot next year.
I run Creo Elements Pro / 5.0 and the setting to export material properties to the STEP file defaults to off (probably to reduce file size.) If you leave it off, you get an all grey model (I added a bit of color to 148 after I imported it.) If you turn on the material properties export setting most of the color comes through. I like the color because it's a bit easier to study the details of the model (and it looks good.) Inventor and SolidWorks probably have similar settings.
