Go to Post Is it really only 5 axes? It looks like that thing could bend time and space. - EricVanWyk [more]
Unread 07-07-2011, 09:27
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Solenoid Valve Recommendation
I'm looking for a 4port, 120psi rated, 12-18 volt solenoid valve for a robot project. What are the best manufactures to look at and which are the most reliable.
__________________________________________________ ______________
Or;
I'm looking for an 850psi two way solenoid valve that's cheaper the Burkett 5404.
My Instructables
Unread 07-07-2011, 13:40
AdamHeard's Avatar
Lead Mentor
Re: Solenoid Valve Recommendation
The voltage of the solenoid is generally separate from the specs of the valve; it's commonly a separate piece on higher end valves. (You can get 12VDC. 24VDC 110VAC, etc...).
I've used SMC, festo and MAC valves, and all are quality products.
You didn't specify a desired flowrate, that really is the great variable here. Everyone will have a valve that meets that psi and voltage, they just get bigger and more expensive with the flowrate.
Unread 09-07-2011, 17:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
If you can, find a pneumatics supplier locally, and walk in. Since you're only looking for one, they may have a floor model or incomplete package that they'll sell cheaply. Also, you'll be able to discuss your needs and hear their recommendations.
