Go to Post "The hardest part about building the robot is figuring out what to build..." - Jeff Waegelin [more]
Unread 08-07-2011, 21:20
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Encoder code...
Hello all, more java questions.
Working with the encoders, after wiring them up. I used the following code.
public static Encoder left_encoder = new Encoder(6,7);
public static void encoder_print() {
System.out.println(left_encoder.get());
With all the necessary stuff between.
However it just prints a string of zeros.
Is there something wrong with the code or should I go check my wiring again?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 08-07-2011, 22:26
Re: Encoder code...
Did you call the start method?
Unread 09-07-2011, 12:37
Mk.32's Avatar
AKA: Mark
Re: Encoder code...
Oh... No... That might be it. Thanks.
