#16
Re: Hemispherical Omnidirectional Gimbaled Drive
Jason |
#17
Talk about rapid prototyping ... Bacon seems to be on top of it! John should post this on his blog...
I like how it's a 'resurrection' of technology. Last edited by JesseK : 12-07-2011 at 09:51. Reason: spelling |
#18
Very, very cool.
I would hope that someone attempts to make this happen at FRC soon. I understand there are some initial issues with making it happen, but I'm sure its only a matter of time before someone figures those out and makes it happen. |
#20
Joyride: very impressed. My only critique (and this is coming from someone who will probably never build a HOG drive) is that the square frame supporting the drive motor seems a bit large. This would limit the total angle of rotation. But you have two hemispheres, so you wouldn't need as much power from tilt from each wheel to get a faster speed.
#21
But building off of what you said, I'm curious as to how this would behave with softer tread materials on a soft surface (as likely to be the application in FRC). The deformation of both the tread and carpet under the weight of your robot would result in a contact patch larger than a single point (obviously). Because of that, different points in contact with the carpet are going to be moving at different speeds (and with different torques), meaning that there's going to be some slip in the drive of the wheel on the carpet. Depending on the radius of the hemisphere, the difference in speeds from one end of the contact patch to the other may or may not be marginal. It's possible that portions of your contact patch might interact with the carpet at closer to their coefficient of kinetic friction than their static friction. In order to mitigate that, larger hemispheres could be utilized. But then the size and range of motion of your gimbal must increase accordingly, as well. Pretty soon that's eating up a considerable portion of your volume, especially compared to traditional drive systems. |
#22
As promised I have pictures. No video since we didn't get to running it.
If you have problems looking at the album just post and Ill upload the pictures! https://plus.google.com/photos/10171...92528705?hl=en You may notice some things have changed from the CAD, this is because we didnt have enough of the right metal to build it to scale so we improvised a bit! Enjoy - Andrew |
#24
-Brando |
#25
.Interestingly for VEX/VRC, if one used a hard/durable material for the tread, without ridges, all of the wear would happen on the rubber tiles. |
#26
One thing I would like to know is, where did the gimbal he used come from? Did he have to fabricate it himself, or is it COTS?
#28
And we come full circle again....... Now in the original discussion nobody talked about changing angles to get holonomic motion but now that you see one built it makes complete sense.
http://www.chiefdelphi.com/forums/sh...ight=cvt+wheel |
#29
Whats to say you couldn't plant a ball caster right in the middle for an FRC scale one? to idle freely
#30
You could do that, or you could just use a nylon/acetal hubcap. But there are still other issues that must be resolved.
