Go to Post That Billfred guy is going to pay for this one. - Bcahn836 [more]
Unread 12-07-2011, 12:53
Dmentor's Avatar
Dmentor Dmentor is offline
AKA: Daniel Bray
FRC #1895 (Lambda Corps)
Dmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant futureDmentor has a brilliant future
Re: Cartesian to angle
atan2(-x,-y)+pi seems to avoid excessive logic.
Dan was here.
2014 VA Semi-Finalist (2363, 1533), Johnson & Johnson Gracious Professionalism Award
2013 Johnson & Johnson Gracious Professionalism Award, Woodie Flowers Finalist - James Gillespie
2012 Chesapeake Finalist (358, 714), Johnson & Johnson Gracious Professionalism Award
2011 VA Semi-Finalist (122, 1111), Johnson & Johnson Gracious Professionalism Award
2010 DC Semi-Finalist (2912, 449), Dean's List Finalist - Chris Dorick, Xerox Creativity Award
2009 VA Semi-Finalist (612, 1908)
2009 DC Semi-Finalist (1712, 176), Imagery Award
2007 CMP Newton Semi-Finalist (68, 111)
2007 VA Rookie All-Star Award, Regional Semi-Finalist (343, 612), Highest Rookie Seed Award (#2), Website Award
Unread 12-07-2011, 13:04
That's what I use. Here's a cheatsheet for other angle choices.
Unread 12-07-2011, 15:19
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
A look up table?
Unread 12-07-2011, 15:21
AdamHeard's Avatar
Lead Mentor
Originally Posted by davidthefat View Post
A look up table?
Why? That's terribly cumbersome compared to the methods already posted.
Unread 12-07-2011, 15:40
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Well, it takes less clock cycles to just retrieve data from an array compared to calculating the angle on the fly. Even though a look up table does take up considerable amount of space in the RAM (Not really since we are dealing with 64 MB of RAM...) Also given the level of accuracy we only really need, about ± pi/180 radian. I think it should be fine.
Unread 12-07-2011, 16:04
AdamHeard's Avatar
Lead Mentor
The cycles are a nonissue on the cRIO, and using the function is substantially less code/setup time.
Unread 12-07-2011, 16:11
Where do you get your information ?
Unread 12-07-2011, 16:27
You must spread some Reputation around before giving it to Ether again.
Unread 14-07-2011, 12:05
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Wait, the crio only has 64 MB of ram? Yes, it does indeed. You learn something new every day I guess.
Unread 14-07-2011, 14:18
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
... and the new cRIO-FRC2 has 128 MB of RAM.
Unread 12-07-2011, 17:20
James Critchley James Critchley is offline
James Critchley is an unknown quantity at this point
Fantastic!
I though you were going to post the trig logic to do all of the calculations. "atan2" is certainly the way to go, transforming coordinates before using it is great.
I need to look at a clock again... right hand rule = CCW!!! See my earlier post.
From a readability perspective, consider defining a macro statement such that.
angle = HEADING(0,0);
atan2(0,0) is undefined in the standard. So for cross platform use, you should check for this as an arbitrary compiler can throw an exception.
if y == 0.0 then y = 1e-8.
Assuming you aren't working with nano-bots this will do nicely and leave your (0,0) point at 0. Unfortunately this adds a comparison operation which, as implied here, are commonly the most costly operations and what you are trying to avoid. This is a prety good arguement for changing the standard.
I did some reading, and as Ether pointed out, ALL recent Intel chips define (0,0) as 0 and this is on the chip and part of the FPU. If you use a look-up table, you need an unbounded (or large) 2D table in x and y... You can manage this by normalization or conversion to a one dimensional problem but atan2 solves it right there in the silicon. There are a host of other issues with the look-up table but the one that strikes me is the effort associated with continually moving a table back and forth through the layers of cache on the chip (Cache is MUCH smaller than RAM). It's not a good option and should not be faster (coding or execution with other intensive code in the loop) or portable to higher resolution applications. In the interest of exhausting all alternatives, the look-up table certainly is "out of the box" and I like it. Keep up the good work!
With the Intel FPU, most modern PC's and Macs will get (0,0) = 0 "right" provided the compiler actually accesses the FPU directly for this calculation (that would be most compilers including gcc). But what does the cRIO do? Is the FPGA intel based? Looks like "Xilinx Virtex" is a custom processor for FPGA? So you need documentation of a firm commitment to define the result as 0, or you need to test and a re-test every time the chip is upgraded which could happen without a "model" change to cRIO.
Unread 13-07-2011, 15:00
Back after 4 years off
FRC #5279
Originally Posted by James Critchley View Post
Fantastic!
There seems to be a lot of confusion as to what an FPGA is, specifically what the FPGA in the cRIO is, if anyone is so inclined it may be of value for someone to write up a description about it. It seems that despite being tucked well within NI's system there is a lot of curiosity about it.
To answer quickly FPGA's and processors are inherently different things. an FPGA or field programmable gate array is basically a huge array of gates, basically if you could take millions of nand gates and organize them in an array such that you can combine them in any way you like you would have the functional equivalent of an FPGA. Obviously the execution of an FPGA is a bit mor ecomplicated but you can visualize what is happening this way. By combining the gates in the FPGA in different ways you can create any logic circuits within the chip, including processors. The Xilinx Virtex is simply the family of FPGA's the one on board the cRIO belongs to. Xilinx is the manufacturer, Virtex is the family. Xilinx does have a few different soft core processors (processors created wthin the FPGA) that you can load onto the chip (MicroBlaze, PicoBlaze etc.). I do not howeve know whether these (or any thing simmilar) are implemented in the FPGA, I would guess they are not.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 13-07-2011, 18:56
Floating point operations are not done in the FPGA on cRIO, they are done in the PPC core's FPU. You can look at the details for it here: http://cache.freescale.com/files/32b...e300coreRM.pdf
Edit: FP instructions are in section 3.2.4.2 (pg 119).
Unread 13-07-2011, 21:16
ajd ajd is offline
FRC #3238
ajd will become famous soon enough
Why would you want atan2(0,0) to return 0, as opposed to any other value? If your point is at the origin, the line between the origin and your point could point in any direction. What is the use case for atan2(0,0) = 0 being helpful?
Unread 13-07-2011, 21:42
Some atan2 implementations throw an exception at (0,0), which is more "correct" mathematically but a pain to deal with as a programmer. You either need to pre-test for (0,0) or wrap it with a try..catch.
Some implementations return NaN (Not a Number). You need to test for this, since NaN can "poison" your result - the result of operations with NaN as an operand is NaN.
By returning a valid number you can avoid having to explicitly test for (0,0) when you don't care. For example, in cartesian -> polar conversions. This makes those calculations a bit easier. For cases where you do care about (0,0), you need to explicitly test before the calculation - but you would have had to do this in the previous methods any way.
As you said, it could point in any direction. The decision to return 0 is arbitrary but convenient. It could just as easily return 0.1234567... but that would confuse us humans.
The wikipedia article goes a little bit into the history if you are interested: http://en.wikipedia.org/wiki/Atan2
I did an fixed-point assembly implementation of Atan2 for the M3-Cortex when I worked for TI. I had a(n extremely nerdy) blast doing it - the arctrig functions have some cool features that make their approximations interesting.
