Go to Post Multitasking is a myth. - DonRotolo [more]
Unread 12-07-2011, 21:34
wmarshall wmarshall is offline
FRC #0011
wmarshall will become famous soon enough
Eclipse WPIlib requires 32-bit libraries on 64-bit linux installs
While migrating our development laptops off Windows and towards Linux, we discovered that WPIlib would not build, preventing us from actually doing development work.
The preverify binary would fail to execute, with the ant script complaining about an IOException.
I poked through a hexdump and saw references to ld-linux.so.2 and glibc, both of which I knew were installed. I took a wild guess and installed ia32-libs (Ubuntu's metapackage for a couple of common 32-bit libraries). After that, there were no issues with either compiling WPIlib or our own code.
TL;DR: If you're running a 64-bit linux distribution, install 32-bit glibc. Otherwise WPIlib will fail to compile.
I find it interesting that there is no precompiled 64-bit binary, despite the ant scripts recognizing 64-bit linux installs.
Unread 13-07-2011, 09:18
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
Re: Eclipse WPIlib requires 32-bit libraries on 64-bit linux installs
If your build uses the -m32 flag during compile, it will build 32-bit objects.
The resulting build will fail because it cannot find 32-bit version of the libraries needed
to complete the build.
Unread 13-07-2011, 10:02
jtdowney jtdowney is offline
Boiler Up
AKA: John Downey
FRC #4302 (Robophins)
jtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant futurejtdowney has a brilliant future
Just a reminder, unless things change next season, you will need a Windows computer to reformat and update the cRIO with image updates. Might be worth it to keep around a Windows VM for that purpose.
John Downey
Lead Robot Inspector - Purdue IndianaFIRST District
Whitney Young Magnet High School/Robophins (FRC 4302) - Mentor (2013-current)
Midwest Regional Planning Committee - Member (2012-current)
Boilermaker Regional Planning Committee - Member (2011-2014)
Robot Inspector (2008-current)
Purdue FIRST Programs - Staff Advisor (2008-2011)
Lafayette-Jefferson High School/Precision Guessworks (FRC 1646) - Mentor (2006-2011)
Unread 30-07-2011, 01:12
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Thanks! This post helped out a lot. 64-bit Linux installs are becoming more prevalent. WPILib probably needs to get a working 64-bit binary of preverify into the plugin to prevent major frustration from users in the near future.
In life, what you give, you keep. What you fail to give, you lose forever...
