Go to Post It is an honor and a privilege to be associated with such an outstanding group of people. And Arefin. - Gary Dillard [more]
Unread 13-07-2011, 17:32
ProgramLuke's Avatar
ProgramLuke ProgramLuke is offline
Captain
AKA: Luke
FRC #2169 (KING TeC)
ProgramLuke is an unknown quantity at this point
Question Brecoflex Treads
I have been doing some research about various thread materials with higher CoF's that could be used instead of the normal roughtop/wedgetop (1.2-1.3). I found a few old discussions on this such as http://www.chiefdelphi.com/forums/ar...p/t-59943.html about BRECOflex as a potential tread supplier. I am not unduly concerned about the slow shipping since a large stock could be ordered pre-season. BRECOflex provides this document which indicates that the CoF of the SuperGrip Green/Blue is 1.5 and the Linatex Red is 1.6. Have any teams used these before and what have your experiences with them been. We would be using these with 4/6'' AM Plaction/Performance Wheels. I am concerned how the backing in the images appears to be ridged. Can these ridges be removed via belt sander or bandsaw in order to mount them on a AM wheel? Also, the Red Linatex does not appear to have the roughtop pattern as the Supergrip treads do. Would this (or some other pattern) need to be machined into the Linatex to take advantage of its higher CoF?
2012 Inaugural Minnesota State High School League State Champions
2012 Galileo Division Semifinalists
2012 Wisconsin Regional Finalists
2012 Wisconsin Regional Entrepreneurship Award
2012 Lake Superior Regional Chairman's Award
2012 Lake Superior Regional Champion
2012 Lake Superior Innovation in Control
2011 Championship Imagery Award
2011 Championship Archimedes Quarterfinalist
2011 Minnesota 10000 Lakes Finalists
2011 Lake Superior Regional Chairman's Award
2011 Lake Superior Finalists
2010 FTC World Championship Finalist
2010 FTC World Championship Edison Division Champion
2010 Minnesota 10000 Lakes Regional Chairman's Award
2009 Minnesota North Star Regional Chairman's Award
2008 Wisconsin Regional Finalist
2007 Wisconsin Regional Champion
Unread 13-07-2011, 18:42
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Re: Brecoflex Treads
My team 1251 used brecoflex treads in 2010. While we did manage to snap one of the treads at the welded joint, we ordered extras and didn't really have any other problems except normal belt wear, so it appeared to just be that individual belt. Words of caution when using Brecoflex always design for proper tension, make sure you have the facilities to make the proper tracking groove if you are using self tracking belt models and make sure the game dictates the use of treads. Finally, make sure your robot will be able to turn this has to do with various design aspects of your treaded drive system, such as pivot idler pulley design and quality. Brecoflex does provide great data on proper tensioning and pulley V groove specs. You may want to look at Gates Mectrol also as I have heard that they are better pricing wise, don't forgot to allow for lead time for your belt order its going to be at least tens days. All in all Brecoflex belts get the job done well for the right game/ robot design.
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 13-07-2011, 19:08
Captain
AKA: Luke
I'm sorry, my original post was unclear.
These treads would not be used in a conveyer tank tread fashion, instead they would be used as a replacement for the standard roughtop/wedgetop tread on an AM Plaction or Performance wheel.
Unread 13-07-2011, 23:02
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Clicking on the images you sent shows that only the Linatex Red and PVC White are 1.1 CoF. The rest are lower than that. I thought that Blue Nitrile from McMaster was either 1.1 or 1.2, but I don't have that right now. Maybe someone else can chime in on that.
Rather than grinding off the teeth, perhaps you could use the stock pulleys or bar stock to make your own wheels to the exact size you want. Then rivet the belting to your homemade wheel. Or you could just cut to size and rivet to the AM wheels.
-T
Unread 13-07-2011, 23:57
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
The trouble with the Brecoflex belts as ordinary wheel tread is that they'll be an order of magnitude more expensive than strips of conventional conveyor belting. Other than that, they ought to work fine.
A belt sander should be able to take the ridges off cleanly. But at that point, you're basically just turning them into ordinary belts. (Not worth it!) Just see if you can find the tread facing materials elsewhere, or ask them about supplying that alone or on a custom thin, flat belt.
Unread 14-07-2011, 00:03
Captain
AKA: Luke
The figure in the document provided for robotics teams shows the CoF's on different surfaces. On the product page the surface is not listed so that isn't really an accurate meter. The CoF's listed in the OP are listed as being measured on carpet.
Originally Posted by http://www.brecoflex.com/index.php?CATID=7&SCATID=64
Name---------------Carpet------Diamond Plate---Polycarbonate Clear
Supergrip Green-1.5-----------0.7-------------------0.7
Supergrip Blue---1.5-----------0.6-------------------0.7
Red Linatex-------1.6-----------0.9-------------------1.4
Unread 14-07-2011, 07:53
Jared Russell's Avatar
Taking a year (mostly) off
When it comes to CoF, measuring it yourself is really the only way to do it. Do not trust numbers you see online from manufacturers - we have seen actual CoF vary by 50% or more on multiple occasions.
The interaction of a wheel with a carpeted surface is complex, and Coulomb friction is but one of the factors. Play around a bit with a few of the common FRC tread materials in a number of configurations (play with the diameter and width of the wheels), and you will find that a 1.3 CoF for something like Roughtop is, at best, a nominal value.
Unread 14-07-2011, 09:04
Captain
AKA: Luke
Has anyone used these that would be willing to share results of some of their testing? I am most specifically interested in the Supergrip Blue, as searches on CD have shown that it wears much slower then the normal brown roughtop.
Unread 14-07-2011, 21:38
jhellr13 jhellr13 is offline
FRC #4272
jhellr13 is an unknown quantity at this point
My team used the treads in 2010. I remember they had great traction and were pretty durable. Turning the robot was something you always had to be concerned about. I never drove that robot, but i remember hearing that you couldn't just jolt into a turn. You had to slowly guide the joystick. It also had great pushing power. We tipped over a robot one time. The treads did have their flaws though. At our regional, after the first practice round, one tread snapped. The extras we had ordered were still being produced at the factory, because we figured we would just order another pair for off season events and future use. Luckily, someone was able to get a hold of another tread company on the west coast to ship it to us in new york overnight for us to use for the weekend. Also, i remember at an off season event, the treads had a tension problem that kept stopping us in the matches. Overall, they worked pretty nicely though. Hopes this helps
Unread 14-07-2011, 23:20
Captain
AKA: Luke
Can you tell me more about your 2010 drivetrain you referenced? Was it a 6wd drop center or a tank tread setup that snapped the belt and provided issues with turning?
Unread 15-07-2011, 16:36
FRC #4272
it was a tank tread setup though i think they drove it in arcade with the option to use tank. not too sure
Unread 15-07-2011, 16:42
Captain
AKA: Luke
I think you may be confusing tank drive (two joysticks) with a tank tread drive system (http://www.chiefdelphi.com/media/photos/29463) .
The treads we would order would be used in a 6wd setup such as http://www.chiefdelphi.com/media/photos/36924.
Unread 15-07-2011, 16:58
1751 used tank treads in 2010.
The steering control setup was something else.
Unread 20-07-2011, 10:40
Generator of Entropy
FRC #2973 (The Mad Rockers)
There is a paper in CD media where my daughter tested the green belts about 8 years ago.
The Paper
The Data
Unread 20-07-2011, 13:38
Chris is me's Avatar
AKA: Pinecone
So more pressure leads to a greater interlock effect and more traction? So for that particular material, less contact patch pushes better. Heh.
I imagine that making a track wider and making a track longer have different effects, since wider increases the number of "spikes" and longer just spreads the load out more.
