Go to Post If I understand what you're saying, you don't understand very far. - Alan Anderson [more]
Unread 19-07-2011, 23:02
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
Question Help needed with RSLogix 5000
Hi! I'm hoping there is someone out in the CD community who has some experience using Structured Text with RSLogix 5000.
Using a variety of sources, I am unable to determine what I am doing wrong with the syntax of my code.
When I verify the code shown below, I receive the following errors:
Error: Line 2: Keyword "END_IF" expected
Error: Line 29: Unexpected end of text found
// If no rows have only 1 light...
if ((ROW1_Value <> 1) AND (ROW2_Value <> 1) AND (ROW3_Value <> 1)) then
	if (ROW2_Value > 0) then ROW2_Value := 1;							// Then check for the first row
	elsif (ROW1_Value > 0) then ROW1_Value := 1;						// to have greater than 0 and set it to 1
	else ROW3_Value := 1; end_if;
// Else if only one row has 1 light left...
elsif((ROW1_Value = 1) XOR (ROW2_Value = 1) XOR (ROW3_Value = 1)) then		// XOR to check for only 1 row having 1 light left.
	if((ROW1_Value = 1) AND (ROW2_Value >= 0) AND (ROW3_Value >= 0)) then		// First possibility
		if(ROW2_Value >= 2) then ROW2_Value := 0;
			else ROW3_Value := 0; end_if;
	elsif((ROW1_Value >= 0) AND (ROW2_Value = 1) AND (ROW3_Value >= 0)) then	// Second possibility
		if(ROW1_Value >= 2) then ROW1_Value := 0;
	elsif((ROW1_Value >= 0) AND (ROW2_Value >= 0) AND (ROW3_Value = 1)) then	// Third possibility
// Else if two rows have only 1 light left...
elsif( ((ROW1_Value = 1) AND (ROW2_Value = 1)) OR ((ROW1_Value = 1) AND (ROW3_Value = 1)) OR ((ROW2_Value = 1) AND (ROW3_Value = 1)) ) then
	if((ROW1_Value = 1) AND (ROW2_Value = 1)) then ROW1_Value := 0;
	elsif((ROW1_Value = 1) AND (ROW3_Value = 1)) then ROW3_Value := 0;
	else ROW2_Value := 0; end_if;
// Else if all three rows have 1 light left...
end_if;
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 19-07-2011, 23:33
Re: Help needed with RSLogix 5000
You have 7 if's but only 6 end_if's.
Unread 20-07-2011, 16:52
FiM Volunteer
Thanks! That was it!
