Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 20-07-2011, 20:09
cjlane1138 cjlane1138 is offline
Team 1138
FRC #1138 (Eagle Engineering)
cjlane1138 is an unknown quantity at this point
PID help
Hey guys,
All im trying to do is make a simple PID that will control some lift motors. Its so that the lift can go to certain presets. I have encoders on the lift, and ive tried everything that i could to get this working. any help? maybe even an example? thanks.
Unread 20-07-2011, 20:52
Re: PID help
Originally Posted by cjlane1138 View Post
Hey guys,
Have you tried using the WPI library provided PIDcontroller class?
Unread 21-07-2011, 05:55
mikets's Avatar
mikets mikets is offline
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
Re: PID help
We have developed a PID control library. One module allows you to do PID control on a motor with encoder. The most useful function is:
void SetHeight(float height, Event *setHeightEvent = NULL);
We used it in the Logomotion game where it controls our ladder to raised to a certain height. For example:
SetHeight(96.0);    //raise the ladder to 8 ft high
You can access our code at:
http://proj.titanrobotics.net/hg/Frc...fd8/PostSeason
The ladder code is in Logomotion/Ladder.h. The PID control motor library module is in trclib/TrcPIDMotor.h
