Go to Post Our prototypes are good and running, now just need to do some magic to transform all that wood to aluminum. :eek: - FIRSTMa2104 [more]
Unread 26-07-2011, 16:00
AdamHeard's Avatar
Lead Mentor
Help with CNC "router"
Someone donated a nice x-y gantry to the team with nice ways, ball screws and servo motors. We'd like to make it into a router.
I started a thread on cnc zone about it with more information.
http://www.cnczone.com/forums/diy-cn...tml#post970640
A few of us can CAM, run CNC's, etc... and We can all run manual machines, but we're CLUELESS about what to do here in terms of getting it running. We know we'll need a controller for the motors, and then a PC with software to run it. We're unsure what the best way to test the motors is as well.
Anyone with any experience with homemade 2d routers if you could point us in the right direction that'd be great!
Unread 26-07-2011, 16:35
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
Re: Help with CNC "router"
http://www.rockcliffcnc.com
Unread 26-07-2011, 16:36
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I have had good, although limited, experience with Gecko drives.
Unread 26-07-2011, 16:44
AdamHeard's Avatar
Lead Mentor
Looks like all of gecko's products are under-powered for this application
Unread 26-07-2011, 18:28
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
This is helpful for the software part assuming that you use AutoCAD, but if you use a 3d program (Inventor or Solidworks) then get Cut2D which is a stripped down version of V-Carve Pro which is what 461 uses. In Vectric's software you have to make a drawing, and then save it as a pdf or dxf and then just assign feed rates and spindle speed (try 3/16 2-flute carbide bit at 2500 rpm and a feed rate of 6-8 inches/minute).
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 27-07-2011, 03:06
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
That's a really heavy duty gantry you got there. Honestly, if you can restore the ballscrew, linear rails/bearings and various other parts you might be able to sell them or the gantry assembly as a whole for a pretty penny and start a CNC router build from scratch using NEMA23's for your steppers. That might be a suitable alternative over working around that behemoth for your application. Ballscrews are real nice but you can get pretty similar performance out of a rack and pinion.
My team has had a real good experience with the Gecko 540 and the pre-fab'd parts from cncrouterparts.com. They're all designed to interface with 8020 or T-slot extruded aluminum.
D5 Robotics: Member since 2007
Drive Team Coach, Design Mentor
Palmetto Regional attendee 2007-2011
2009 QF, 2010 SF, 2011 SF
Unread 27-07-2011, 13:20
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Holy huge stepper motors batman!
I like thermal's idea.
Unread 27-07-2011, 13:28
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Adam,
We currently use a CNC Router that uses a controller by A2MC.
http://www.a2mc-cnc.com/
Maybe they might have resources and accessories that can bring your project to life.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 27-07-2011, 13:32
techtiger1's Avatar
techtiger1 techtiger1 is offline
Coach Drew?!?!
AKA: Drew Disbury
FRC #1251 (TechTigers)
techtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond reputetechtiger1 has a reputation beyond repute
Send a message via AIM to techtiger1
Adam you may want to take a look into the motors this company uses. I don't know what type of work your planning to do but 1251 has a couple small divinci routers from them and they do the trick for routing work. http://www.techno-isel.com/
Team 1251 The TechTigers
"Inspiring future innovators, one stripe at a time"
2004 Rookie All Star Orlando Regional
2006 Palmetto Regional Winner
2007 Orlando Regional Winner
2008 Orlando Regional Winner
2010 Orlando Regional Winner
2013 South Florida Regional Winner
Unread 27-07-2011, 13:49
AdamHeard's Avatar
Lead Mentor
Yes, they are huge motors, and servomotors at that, not steppers.
The Mechanical system needs no restoration, and both motors are there. One appears to be broken, but we've found replacements for $100. We need a controller, spindle, and then software as far as we can tell.
We're really not interested in selling it, this bad boy is rigid and the motors are real powerful. It also seems like a lot less work as this is mechanically good to go minus a table. Having a router in house to us isn't terribly useful if the cut speed is slow and we're limited to light materials. We want to do some serious work on it, or not spend hundreds of hours getting it made setup and running.
Thanks for the advice guys, I'll be reading about what all these companies offer when I get some time. The biggest variable being what to do for a spindle, followed by what controllers to buy for our existing (200V 100-300W) AC servomotors.
Unread 27-07-2011, 17:43
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
Do you already have an x-axis for this build? All I see is a gantry in the pictures.
I ask this because designing an x-axis around this system is going to be quite expensive and labor intensive. This is quite a large build.
I currently have a CAD model for a future build I want to do with the team that is R&P, easy assembly, 500ipm rapids, rigid enough for light steel work, and capable of mowing through aluminum and delrin. Parts list and price list included. For the most part there's little machine work, just cutting 8020 and getting some reinforcement plates made via waterjet. If you're interested, shoot me a PM i'll gladly send over pictures or even the assembly for your perusal. Though, i'm sure you've read through all the build logs on cnczone and know whats out there for DIY. What a great treasure-trove of information over there.
I must say though, if you go ahead and do a build around that gantry, please post up a build log because it's going to be a real impressive machine and i'd love to see it
Unread 27-07-2011, 17:48
AdamHeard's Avatar
Lead Mentor
In that picture, the long and exposed axis is the X. The axis parallel to the horizontal frame of the picture with the boxes on it is the Y. The Y has somewhat limited travel, but plenty for our purposes.
Unread 27-07-2011, 18:21
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
I imagine the machine it was taken off of has that as your Y and Z. I can't see it functioning too well as your X+Y.
Unread 27-07-2011, 18:30
AdamHeard's Avatar
Lead Mentor
Interesting point, that is probably what is was intended for, but when we got it whatever was mounted where a spindle was was mounted facing the floor in that pic, making us think x-y.
In this configuration it would have very limited Y travel when compared to X, but that is not an issue for us. We really only need 8" or so of Y.
Unread 27-07-2011, 18:33
DonRotolo's Avatar
Back to humble
FRC #0832
Spindle: You can initially go with a wood router (1 to 1.5 HP) with a variable speed controller, and stick with 1/4" shank mills, to save costs and get a feel for what it can do. Easily mills aluminum, steel not so much.
Later, you can engineer a real quill once you learn the kinds of rigidity and precision required. For now, a reasonably rigid Z axis with perhaps 6-12" of travel will be fine. (Trust me: approach this like a robot - build a low-investment prototype first, then redesign after learning the lessons)
Controllers: Obviously you use a computer to 'control' it, with software like MACH3. What you're looking for a nice "driver" board, and possibly a power supply as well. eBay can be your friend here, several companies such as Omron, Mitsubishi, Panasonic, etc. make boards that will drive your motors. Plan on looking carefully for one that drives 200V AC at over 1.1 A (220W - buy one a little bigger). For three phases expect to spend $300-800, more if new.
There's a lot of expertise here, keep asking questions.
