Go to Post 254 isn't just good at building their robot. They're also good at taking pictures of it. - Chickenonastick [more]
Unread 29-07-2011, 02:34
093611k 093611k is offline
VRC #0021
093611k is an unknown quantity at this point
Line Follower
Hi All there is a problem face while im doing the line follow. I found out that the detection by the vex line sensor is rather slow. I wonder if u guys had encounter this problem or not... If yes, i will appreciate some suggested solution... Please help!!!
Unread 29-07-2011, 10:23
Andrew Lawrence
Posts: n/a
Re: Line Follower
I don't do VEX, but I do have experience with light sensors, which are used to follow lines. FIRST off, do you have it in an area where it has enough light? Not just light from the outside, I also mean light coming to the sensor area. If the sense itself is not receiving enough light, it may not work, and/or it may take longer to find the line, since there isn't enough light to distinguish line from no line.
As for the slowness, do you mean that the line tracking itself is slow, or that it just takes a while to recognize the line, but after it does the robot goes through it quickly.
Unread 02-08-2011, 00:16
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
Re: Line Follower
Are you sure that it is the actual line sensor itself? You might try connecting it to an Arduino to see if you get similar results. Also, you might try creating a separate thread in thread in the code so that the line sensor's code will run much faster.
FRC Team 1477 - Texas Torque
The Woodlands, Texas
Unread 02-08-2011, 00:25
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: Line Follower
Let me qualify this by saying: I have no experience with vex whatsoever.
However, I have programmed quite a bit on a number of robot platforms. I find it very unlikely that the sensor is to blame, it is probably your code. Without having it in front of me I don't know what is wrong, but I would try Tom's suggestions. I just want to remind you not to jump to conclusions.
Unread 02-08-2011, 08:14
Re: Line Follower
K,
The VEX line follower uses infra red emitters and detectors. These can be overpowered in the presence of strong IR radiation such as in direct sunlight, or from security cameras close to your test station. They are programmable and to allow you to vary parameters to suit your conditions. Please follow the guidelines and keep the sensors mounted close to the line you are following, 1/8" or 3mm above the line is optimal. In the presence of strong light, it might work better if you shade the sensors so that ambient light is less of an issue.
