Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Unread 28-07-2011, 22:37
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
pic: 7068/7075 Aluminum Gears
Unread 28-07-2011, 22:42
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: pic: 7068/7075 Aluminum Gears
I was very jealous of your gearboxes in St. Louis, and I'm very excited to hear that some of your gears will be available to purchase!
The first obvious questions: What sizes/arrangements of gears will you be offering? From the hex bores in some of the ones pictured, I'm guessing most will be drop in replacements for some of the standard AM ones. Pinions? Pricing?
Unread 29-07-2011, 10:14
AdamHeard's Avatar
Lead Mentor
The gear sizes shown are somewhat arbitrary; it was the usual custom 973 gearbox with gearteeth picked for our ratios. Also, the bores on the dog gears do not match AM. They were made for teams directly. The gears weren't perfect as some people pointed out at champs, and had worn of the anodizing completely on some (a minority); they still ran and never yielded on us however (through 4 competitions so far, and two more coming up). RC tells me him and the shop know the issues, and are certain they won't be repeated. I know he would only sell quality gears.
I would assume if he were selling he would be making standard sizes, and presumably drop in replacements. I personally would love "toughbox" style gears to give us more easy single speed spur gearbox options. Direct replacement for the AM shifter set would be cool too.
So yeah RC, that's what WE want ^^^^^^.
Unread 29-07-2011, 11:05
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
We (2415) used these gears the entire season through 3 regionals, Champs, and IRI and they have held up perfectly. The anodizing has worn a bit but from what I hear production gears will be getting a much harder finish. Also the machining quality on these gears was much higher than anything I have seen offered for FIRST robotics.
Mentor 2415
Unread 29-07-2011, 11:28
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
It's perfectly normal for the hard anodize to wear a bit at the tooth interface. If you look at the 254/968 2007 transmissions you'll see exactly that. We noticed this happen within a few hours of run time, but after that saw no wear of the actual tooth profile.
2001-2004: Team 100
2006-Present: Team 254
Unread 29-07-2011, 11:29
AdamHeard's Avatar
Lead Mentor
Exactly, the tooth profile was fine.
Unread 29-07-2011, 11:46
Chris is me's Avatar
AKA: Pinecone
Just gotta say, if these gears are commercially available they will completely change how I design robots.
Unread 29-07-2011, 13:16
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Will you be a legal vendor for FRC teams?
Unread 29-07-2011, 13:18
AKA: Sean
I'll go ahead and answer for RC and say that he will be a legal FIRST vendor. I'm pretty excited at how easy it is about to become to get quality aluminum gears. This will be a substantial weight savings for any teams that are willing to try something new.
Mentor 2415
Unread 29-07-2011, 14:10
R.C.'s Avatar
Most of them will be drop in Replacements, Currently we are planning to have toughbox and the first two stages of supershifter gear replacements and then some other ratios that I think many teams will be pleased with.
I'll put more details up the pricing/site/pinions in the following weeks.
Sean is correct.
We are experimenting with a few different coatings. There will be more information in the following weeks. 1323 was also pretty happy with the gears and loved the weight savings.
-RC
R.C.
MadTown Robotics Team 1323
Unread 29-07-2011, 15:44
Nemo's Avatar
Team 967 Mentor
AKA: Dan Niemitalo
Well, this is basically pretty awesome. I wish you guys a lot of luck, and I'll be very interested to see the prices when things get rolling.
Unread 31-07-2011, 20:15
Conor Ryan Conor Ryan is offline
I'm parking robot yacht club.
FRC #4571 (Robot Yacht Club)
Conor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond reputeConor Ryan has a reputation beyond repute
The original 2007 254/968 gearbox made me cry a little bit when I first picked it up. I'm very happy that somebody is finally bringing these to market because I'd like to experiment with spur gears on a bicycle eventually.
