Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 30-07-2011, 01:12
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Eclipse WPIlib requires 32-bit libraries on 64-bit linux installs
Originally Posted by wmarshall View Post
While migrating our development laptops off Windows and towards Linux, we discovered that WPIlib would not build, preventing us from actually doing development work.
The preverify binary would fail to execute, with the ant script complaining about an IOException.
I poked through a hexdump and saw references to ld-linux.so.2 and glibc, both of which I knew were installed. I took a wild guess and installed ia32-libs (Ubuntu's metapackage for a couple of common 32-bit libraries). After that, there were no issues with either compiling WPIlib or our own code.
TL;DR: If you're running a 64-bit linux distribution, install 32-bit glibc. Otherwise WPIlib will fail to compile.
I find it interesting that there is no precompiled 64-bit binary, despite the ant scripts recognizing 64-bit linux installs.
Thanks! This post helped out a lot. 64-bit Linux installs are becoming more prevalent. WPILib probably needs to get a working 64-bit binary of preverify into the plugin to prevent major frustration from users in the near future.
In life, what you give, you keep. What you fail to give, you lose forever...
