Go to Post Fame is a funny thing, you can do nothing and get it, and do everything and get none. For me, it's not fame, but infamy that follows me. - Joe Matt [more]
Unread 27-07-2011, 19:19
AdamHeard's Avatar
Lead Mentor
Re: Help with CNC "router"
So, if we were to mount a spindle on the "Y" which is really the Z in the current orientation, we'd get very limited travel.
But what if we turned the whole thing over, and hung the Z down below it? We'd still geometrically get the same travel, but do these need to be run in the orientation they were designed for?
Unread 27-07-2011, 19:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A router is certainly the cheapest option, but I'd be worried it's RPM would be a little fast, it's bearings might not last for heavy milling in aluminum, it probably wouldn't take larger endmills, and it would be really loud.
There's this spindle but it's not cheap and a little on the small side. Also, it could stand to be a little faster. Nice thing is, it's a complete unit and it's R8.
You could use a Tormach spindle assembly which is pretty nice (they have two different ones), but it would run you about $1100. It's a bit large. I'm not sure how it would fit in with the scale of your machine.
I'm not aware of any other spindle assemblies for sale separately. You could contact some mill manufacturers though such as Industrial Hobbies or LatheMaster and see if they'd be willing to sell you just a spindle assembly.
Of course, with all of these options, you'd still need a Z-axis.
Unread 27-07-2011, 20:03
Thermal's Avatar
Thermal Thermal is offline
Drive Team Coach
AKA: Ryan Brown
FRC #1293 (D5 Robotics)
Thermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to beholdThermal is a splendid one to behold
Wood routers are quite capable of sheet aluminum work but you have to get a little creative about it. http://www.vhipe.com/product-private/SuperPID.htm is a great tool for that.
You're correct about the bearings though, heavy aluminum work will destroy wood router bearings in a few months. Handily though, replacement bearings are relatively cheap and not too difficult to replace.
D5 Robotics: Member since 2007
Drive Team Coach, Design Mentor
Palmetto Regional attendee 2007-2011
2009 QF, 2010 SF, 2011 SF
Unread 28-07-2011, 20:28
DonRotolo's Avatar
Back to humble
FRC #0832
Depends, some can, some cannot. Consider moving the material in X and Y beneath a fixed gantry for Z
Yes, so the wood router is a temporary solution ONLY, a $50 investment to get a feel for the machine on the cheap. Then a real spindle can be developed, after the hard lessons have been learned inexpensively.
Unread 29-07-2011, 01:06
AdamHeard's Avatar
Lead Mentor
Looks like we might have the controller with it, need to poke around more.
We came up with the basic simplest option. Use the x-y as is, sell the motors on it, make a basic z-axis w/ spindle, and then buy one of those high powered stepper motor, software and controller packages. This would get us about 16x48" of travel.
We still have more research to do, but we're committed to using this guy during our 2012 season.
Unread 29-07-2011, 13:54
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
A spindle option for you:
http://www.a2mc-cnc.com/Spindles.html
We use the Elte 3HP @ 18,000 RPM and have been quite happy with it. We also have an auto-mister, which is a very nice feature for cutting aluminum. We cut up to 1/4" thick plate on our setup - multiple passes of course.
AXYZ Router (http://www.axyz.com/) might even quote you an entire Z assembly + spindle. They build complete CNCs based on the A2MC controller, and do some custom work as well. Maybe they can give you a pre-fabbed Z assembly + spindle, and just let you figure out how to mod it to mount it on your X/Y gantry. If you go this route, again I'd highly recommend the mister.
As an aside, here are some options for stepper controllers if you don't get yours working, or if the old ones don't support ModBus:
http://www.a2mc-cnc.com/motors_drives.html
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 29-07-2011, 14:21
AKA: Mr. Lim
Team 188 has been cutting aluminum on a CNC router equipped with a wood router as a spindle for a number of years with a lot of success. Patience, conservative cut depths/feed speeds, a good cutter, and someone to stand over it with a vacuum to clear chips, and coolant are key. Don't expect to be able to hold tolerances to press-fit bearings though!
Here are the cutters that we swear by, and 188 also has adopted:
http://www.onsrud.com/xdoc/SuperO
We run them at 18,000 RPM. I think 188's wood router is a fixed speed at 24,000 RPM which is a bit fast I think, but it is possible. The single flute in the cutter makes a big difference in being able to run at these speeds.
Unread 29-07-2011, 14:29
Thermal's Avatar
Drive Team Coach
AKA: Ryan Brown
You should create an effective dust shoe, then you don't even need a person to stand around with a vacc in hand
Unread 29-07-2011, 18:10
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Mr Lim, we do the exact same thing but we cap out at 14k rpms. Also we just added "compressed air" and just dry cut aluminum. With two flutes you need coolant but with single flutes you don't even need coolant.
For our machine, the reseller does not advice coolant in any spray form but they recommend using drops shown here:
http://www.techno-isel.com/h850/html...ection_22.html
-RC
R.C.
MadTown Robotics Team 1323
Unread 31-07-2011, 01:52
AdamHeard's Avatar
Lead Mentor
We were able to find the controller and manual for it, haven't been able to test yet (Need to find 220 single phase...).
The manual explains a lot, especially the lack of spindle and odd axis arrangement.
It actually is a Yamaha "FLIP Series" robot. Which appears to be a stripped down and repackaged router. So, although it looks like the 2 of the 3 axis from a large gantry router, this was it's original configuration.
Unread 31-07-2011, 11:43
DonRotolo's Avatar
Back to humble
FRC #0832
You know that every house & building in North America that has "110 volts" also has 220 single phase, right?
Finding the book was HUGE, that'll almost guarantee success...even if you decide to use different hardware.
Unread 31-07-2011, 12:07
AdamHeard's Avatar
Lead Mentor
Yes, it's just the hooking up that we need some help with, we have 220 single for one of our lathes but there is no plug, it's hard wired. We need to bring in some outside help to make it happen. I don't feel like a few students and I wiring 220 is something we should be doing.
Unread 31-07-2011, 16:36
DonRotolo's Avatar
Back to humble
FRC #0832
Eh, the worst that could happen is you get killed
Um, yeah. Better safe than sorry. 220 is nothing when you have the expertise, but WAY deadly and not at all forgiving of mistakes. Probably easier to bring the whole thing to someone's house, where there's a plug wired for 220 already, and just wire it up with the correct plug.
