Go to Post Maybe if we get lucky [the GDC] will just say chute door. - IronicDeadBird [more]
Unread 31-07-2011, 15:09
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
Has anyone ever used a Computer Mouse to locate themselves on the field
I have worked on an inertia navigation system for aircraft (http://en.wikipedia.org/wiki/Inertial_navigation_system) and was thinking of how to do something similar on the cheap. Last year I was able to see how different teams located themselves on the field for autonomous systems. Some worked well and others, eh...
So I am curious if anyone has ever tried using one or more laser computer mice to replicate an INS system. As long as my tolerance is over 12 inches in the x and y it should work great. In fact if I put two or three on their and was really picky about my starting position I bet it could hold a tolerance of less than a few inches. It’s cheap, the drivers exist and it does not rely on any external references.
Any thoughts?
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
Unread 31-07-2011, 15:29
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: Has anyone ever used a Computer Mouse to locate themselves on the field
I know team 972 tried this before they merged with our team in 2008. IIRC, they used just a mechanical mouse, where they had the ball running against the ground. I don't think they had all too much success, but it looked fairly promising. I think with laser mice, you will run into a similar problem of having to have it very close to the ground. This could have been a problem for the last two years (bumps + lip by goal for Breakaway, and lip by poles for Logomotion).
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 31-07-2011, 15:31
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
That makes sense.
Good to know though.
Thanks
crazy engineer
helping team 1389
Unread 31-07-2011, 15:34
A few teams used a follower-wheel system in 2009, using unpowered omni wheels attached to encoders or something similar.
Unread 31-07-2011, 16:14
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
This has been my pet project for a while. As long as your robot pivots around a single point and doesnt strafe, then a follower wheel and a high accuracy gyro should be able to integrate for position. Alternatively if you can find a high speed trackball (over 15fps, which I have so far been unable to do), you could use that and strafing wouldn't be an issue.
If you are really interested in using a laser mouse, i would suggest looking up the razor gaming mouse (as it is the only one that i know is fast enough), then milling it a plastic mount with rounded edges to get over bumps, and spiring tensioning the mount against the ground.
Unread 31-07-2011, 16:30
DonRotolo's Avatar
Back to humble
FRC #0832
(Laser mice don't actually use lasers. And in 2011 "lasers" were not allowed. FWIW.)
Anyway, if this were combined with some distance sensors (I'm thinking ultrasonic) you should be able to recalibrate your position from time to time, when conditions are 'right'. Add odometry and a 2-axis accelerometer and you might be onto something...
Unread 31-07-2011, 16:49
Perhaps you meant to say "replace" instead of "replicate".
Mice don't work on an inertial principle.
What kind of drivetrain would you be using?
Unread 31-07-2011, 17:00
lemiant's Avatar
the Dreamer
AKA: Alex
Why so many sensors? Im especially interested in the accelerometers, how would you use them? An accelerometer is pretty much useless for tracking given our restrictions (as I'm sure the asker knows), since you needs an impressively accurate attitude value in order to filter out gravity.
EDIT: would laser mice be allowed in the 2011 rules?
Unread 31-07-2011, 17:02
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
I know some of these were used for traction control. They would compare the rotation on their powered wheel encoders to the rotation in the unpowered wheel to see if they were actually moving as fast as they thought they were (if at all).
I know team 51 had some kind of location on their drivers station in 2010. I'm not sure why they used it, but it worked pretty well.
Unread 31-07-2011, 17:18
<R02-D> prohibits any device with an exposed laser. I highly doubt that you could argue that the mouse's optics are not exposed.
BTW, a number of teams use accelerometers without any problems. Gravity is either accounted for or ignored, but the accelerometers are reasonable in cost and complexity.
Unread 31-07-2011, 17:40
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
This idea has been thrown around for years, in FIRST and elsewhere. I don't think anyone has really solved the problem of carpet providing a poor surface for taking measurements. I believe there were a few optical mouse systems in 2009, when the fibreglass panels were being used as a floor surface.
There are actually a few optical mice that use real lasers.
The laser rules have been a bit of a mess in the past, but the general trend has been to prohibit them if exposed. ("Exposed" is ambiguous—exposed to what, when, and on purpose?)
Unread 31-07-2011, 17:46
rahilm's Avatar
AKA: Rahil Mehta
Using accelerometers to yield position though would be fairly inaccurate. Integrating once to get velocity shouldn't be too bad, but the second integration won't be too accurate, especially considering that you're going to be 1 processor cycle behind (time wise) on position.
Edit: This is what I mean by being 1 processor cycle behind. To integrate, you basically have to use Reimann sums in this case. For best accuracy, you'd want trapezoidal sums, so for 1 position value, you need 2 velocity values, so 3 acceleration values. This means you'd have to integrate acceleration for 2 cycles to get the two velocity values required for a single position value, putting you 1 cycle behind realtime.
Unread 31-07-2011, 18:21
lemiant's Avatar
the Dreamer
AKA: Alex
Gravity could be concievably ignored, but even a slight rock of the robot would make position tracking invalid. For about 4 grand you can get a commercial grade INS that will do all the work for you, but that is obviously not viable.
Unread 31-07-2011, 18:23
staplemonx's Avatar
The Idea Guy
AKA: JJ Biel-Goebel
I meant replicate the functionality of an INS system. Instead of using gyros and accelerometers and an initial location, i use an initial coordinate and a set of x y inputs from a mouse.
crazy engineer
helping team 1389
Unread 31-07-2011, 18:32
What kind of drivetrain will you be using?
