Go to Post Am I just a freak? - Josh Hambright [more]
Unread 31-07-2011, 08:12
SMHS SMHS is offline
Jay Maine
AKA: Dan Lemieux
None #3930
SMHS is an unknown quantity at this point
What programming lauguage should we start with?
We are setting up a new team and we need to learn about programming. Which software or programming language should we start with?
We have very little experience with program and need to learn quickly. Where do we start?
Unread 31-07-2011, 08:38
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Re: What programming lauguage should we start with?
I'm not a programmer, but I would recommend using labview. The language is really simple since it's visual and you can drag and drop. It lets you get at the actual fundamentals in the logic of programming without losing frustration over the complicated syntax of something like C++.
Unread 31-07-2011, 09:59
With little or no programming experience, you'll probably find LabVIEW to be the fastest path to good robot code. The tutorials at http://www.frcmastery.com/ will help you get started.
Unread 31-07-2011, 15:17
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
If you have no one with any programming experience labview will probably be the quickest to learn.
However if you can find some students with some programming knowledge going the C++/C/Java would be feasible.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 31-07-2011, 15:56
Colin P's Avatar
Colin P Colin P is offline
MTU Robotic Systems Enterprise
AKA: Colin Putters
FRC #0857 (Da Yooper Troopers 3771, Unbolted Puppeteers 4363)
Colin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to beholdColin P is a splendid one to behold
Labview is a scripting language with a nice GUI. You can pretty much click your way through it. You don't have to construct new code as text like C+ so it's easier for people with little experience.
Unread 31-07-2011, 19:37
torihoelscher's Avatar
torihoelscher torihoelscher is offline
Wow I feel old
AKA: Princess Leia
torihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant futuretorihoelscher has a brilliant future
Send a message via AIM to torihoelscher
LabVIEW is the best to start with.
Whomever agrees with LabVIEW say "Aye"!!!!!
Tori Hoelscher
FLL
FTC
FRC
"May the [mass x acceleration] be with you"
"Aren't you a little short to be a storm trooper?"
Alumni of Team 79 Krunch.
Unread 31-07-2011, 19:43
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
I think its important to consider what you want to get out of the students programming.
Labview is great for an easy system to get the robot running with an easy learning curve(though complex systems are about the same between C++ and Labview). Labview is also great for those students who would be interested in programming for industrial robotcs since thats what most in that industry use.
However as a teaching tool using a language like C++ will provide a better platform for understanding programming in general and is much more like languages used in most other programming industries.
Pick which platform will meet the needs of your robotics program and run with it.
KK4KQO
http://voltair.us
Unread 31-07-2011, 21:22
Mr. Mike's Avatar
Mr. Mike Mr. Mike is offline
FRC #3138 (Innovators)
Mr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to allMr. Mike is a name known to all
Go with what you have in resource. If you can find a mentor, or another team use what they have experience in.
Unread 31-07-2011, 23:25
If what you mean by "scripting language" matches the common usage of the term, then you are mistaken. Scripting languages are usually intended to be procedural ways to control a program that would otherwise require user input. While LabVIEW can be coerced into doing procedural actions, it really "wants" to do things in a strict dataflow fashion.
Also, LabVIEW is a graphical language, not a text-based language with a GUI on top of it.
Unread 01-08-2011, 00:51
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
I would suggest LabVIEW. Since NI also makes the hardware, it makes it a tad bit easier. Plus they are much more willing to give help if its their hardware working with their software. The saying we normally use is that LabVIEW is easy to learn but hard to master. So a basic understand will function well within FIRST. And some major groups, like government and industrial plants, are using more of graphical languages, which means using it would help your students.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 01-08-2011, 04:24
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Now, I am not sure how stable the python interpreter is for the cRio, but it might be a good one to check out. It can be used as a stepping stone into Java or C++. There would be more setting up to do with Python I assume. I would personally use C++ just because it lets you fail A LOT. I mean it is like trying to ride a bike without training wheels. (Sorry, I still do not know how to ride a bike after 17 years of being on this Earth0 But learning comes from failures. It lets you dive deeper into the system, makes you think a bit more. Like why I should use a pointer and what a pointer actually is.
Unread 01-08-2011, 09:24
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
LabView is great, easy to pick-up, easy to pass along, and generally I find easier to teach.
C++/Java on the other hand, while some would consider harder to grasp at first, are still very feasible.
The one thing that is important to remember is that one language is never better then another. It comes down to what you want to do and accomplish, as well as what the programmer in mind feels most comfortable with.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 01-08-2011, 13:21
Luckryan's Avatar
Luckryan Luckryan is offline
Currently Head of Design and Built
AKA: Amy Wiegand
FRC #2915 (Oregon City Pioneer Robotics Organization/Riverdale Robotics)
Luckryan is an unknown quantity at this point
LabVIEW, I am a programer and I have used all of the lauguages and LabVIEW is pretty easy to learn. I can send you some power points if you want help with LabVIEW.
-Amy Wiegand
Robotics regional, friends, my second family and much, much more: "Robotics is what we do, everything else is just a hobby."
Teams:
Team 2550 Oregon City Pioneer Robotics Organization (OCPRO)
Team 2915 Riverdale Robotics
Unread 01-08-2011, 22:58
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
If nobody on your team has experience with Java, C, or C++, then go with LabView, but if anyone on your team has experience coding in any of the three programming languages listed above, then go with C++ or Java.
FRC Team 1477 - Texas Torque
The Woodlands, Texas
