Go to Post What can you do? The more time you waste here speculating the less time you have to work on the robot. Go! Build Robots! Now! - Jessica Boucher [more]
Unread 01-08-2011, 22:24
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
Team Role: CAD
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
pic: 6 Wheel drive practice
Unread 01-08-2011, 22:25
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: pic: 6 Wheel drive practice
Interest. Why are the cims placed differently?
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 01-08-2011, 22:28
Kyoshirin's Avatar
Kyoshirin Kyoshirin is offline
Renaissance Man
AKA: David
FRC #1188
Kyoshirin is an unknown quantity at this point
Is the battery cable long enough to reach the PD board?
Prototypes ARE the final product.
Unread 01-08-2011, 22:34
ttldomination's Avatar
Sunny
(A) I actually don't see a PDB on that CAD.
(B) You can cut longer wires from the PDB to your battery, so this really isn't that big of an issue.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 01-08-2011, 22:39
It's to line up shafts if I'm guessing right. The placement is a 90-degree rotation to adjust for something not being quite right--I forget just what.
As far as the battery cable, you can have your own longer one (provided the gauge is right). However, that size of cable gets pretty heavy--I'd personally move the PDB closer to the battery and use lighter cable for longer runs.
ttldomination, I'm pretty sure that's the PDB behind the cRIO.
Unread 01-08-2011, 23:43
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Digital Sidecar.
Im also guessing brian just slapped on the electronics for picture aesthetics-- no real reason for specific locations.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 01-08-2011, 23:49
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
How is the chain tension adjusted?
Unread 01-08-2011, 23:55
It is b/c these gearboxes don't come oriented differently for right and left side modules. You have to have a 90* rotation or I believe assemble it essentially backwards, but I have never played with them myself so the only one I'm sure of is turning one 90*.
Unread 02-08-2011, 00:13
Tommy.Brown's Avatar
Tommy.Brown Tommy.Brown is offline
Lead Programmer
FRC #1477 (Texas Torque)
Tommy.Brown is an unknown quantity at this point
You might want to try adding sprockets between each set of wheels to tension the chains, other than that, very nicely CADed. Congrats.
FRC Team 1477 - Texas Torque
The Woodlands, Texas
Unread 02-08-2011, 00:16
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
This is correct, a supershifter has a 5" square face. Looking at a supershifter head on the shaft comes out of a hole 1.5" from the right, and 1.5" from the bottom, this necessitates it being rotated 90 degrees when you place it on the other side, in order for the shafts to line up. (It you don't understand draw it on a piece of paper and then flip it to replicate being placed on both sides, and you will get it.)
Unread 02-08-2011, 00:17
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
No issue except for the energy lost to electrical resistance...
Unrelatedly, I'm curious what you modified on the super shifters. Except for removing the housing, they look pretty close to stock configuration to me.
--Ryan
FRC 766, 2015-, Mentor
Unread 02-08-2011, 08:00
iScout
Team Role: CAD
About the whole PDB thing; I just tossed a basic electronics board in to show where things might go. I don't know where the electronics would go on the actual robot because this was designed without a specific game in mind.
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
