Go to Post Don't date anyone on your team unless you are POSITVE that you will be able to handle yourself professionally, not only during your relationship, but even after it ends. - Jaine Perotti [more]
Unread 02-08-2011, 00:16
lemiant's Avatar
lemiant lemiant is offline
the Dreamer
AKA: Alex
FRC #4334 (Alberta Tech Alliance)
lemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond reputelemiant has a reputation beyond repute
Re: pic: 6 Wheel drive practice
Originally Posted by Akash Rastogi View Post
It is b/c these gearboxes don't come oriented differently for right and left side modules. You have to have a 90* rotation or I believe assemble it essentially backwards, but I have never played with them myself so the only one I'm sure of is turning one 90*.
This is correct, a supershifter has a 5" square face. Looking at a supershifter head on the shaft comes out of a hole 1.5" from the right, and 1.5" from the bottom, this necessitates it being rotated 90 degrees when you place it on the other side, in order for the shafts to line up. (It you don't understand draw it on a piece of paper and then flip it to replicate being placed on both sides, and you will get it.)
