Re: pic: 1675's REAL IRI Upgrade
Very interesting. I would imagine that the driving style was changed to tank drive rather than the typical mecanum pattern, is this correct?
Not hating on 1675 or anyone, but I'm not sure why everyone's praising this as if its a new design or a radically different/improved design, in comparison to a normal tank tread drive. Unless you can somehow strafe, the wheels are now no different than a normal tank tread drive--maybe even worse because the tread is zip-tied and not against a flat surface. However, i would love to be disproven on this. -duke |
I consider the picture a DOWNGRADE. mecanums work if you do it right. gear them high and try to keep the weight semi-balanced. I know there will be some angry replies to come from this from the "mecanum haters" out there. |
This "upgrade" was a friendly joke / prank from the kids on 1625. They obviously removed them, despite some of us friends teasing them that it was a big improvement. 1675 responded by hiding hundreds of mecanum rollers in 1625's tools.
![]() I think Einstein may not be the best sample for pointing out a correlation between traction drives and success, but I certainly can name far, FAR more top robots with traction drives. I certainly don't think the best teams are just too sucky at using mecanum drives to appreciate them! Last edited by Chris is me : 04-08-2011 at 21:08. |
Im curious as to how many top teams have actually tried Mecanum. Because its not that the people that dont use Mecanum are the top teams, its that the top teams seldomly use mecanum. Chris, you seem to know every team , so whats one of the best teams you saw this year ( or any year) that used mecanum? Because im pretty sure the big name teams (71, 111, 67, 148, 233) have never used mecanum.------ In other words, regarding tank v. mecanum, correlation does NOT imply causation. Last edited by Duke461 : 04-08-2011 at 21:25. Reason: missing an "n" |
The best mecanum team this year was IMO 2826, which had an alternating drivetrain. If you go by FRC Top 25, not one team is "pure" mecanum. The best team probably to go pure mecanum was 2337, but I do think they would be just as good with a traction drive. Quote:
#7
the reason a lot of top teams use: traction: they have used it for so long and thats what they are used to and have plenty of spare parts for crab: they have plentiful human and/or capital resources or they have used crab for so long they already know the drivetrain design before the beginning of the season. i do recall a pure mecanum system being a division finalist. curie 2008. 2171 robodogs from crown point, IN. look at some of thier footage on thebluealliance from boilermaker regional... they had that crab drive rocking... and that was under the IFI system. octanum sounds like a good offseason project but a waste of weight and expenses... the key to mecanum is speed... gear it high (stock toughbox nano will do) and go... you can have a scale-down button if it is too quick by itself. |
#9
Now look, this was supposed to be a lighthearted thread where both sides would laugh about a prank everybody enjoyed... |
#10
intel i860- was a RISC, not a x86 CISC cpu. intel itanium- wasn't x86, atari 5200/atari 7800- the 2600 was good enough, so there wasn't a need to upgrade wankel engines- radically different than existing piston designs microsoft bob- people liked the existing windows interface, no upgrade desired there are more, but if there is no perceived need to change, why do it? if what you have doesn't work or you are starting new, then that is a different discussion. point is that many top teams have been good for a long time and they never had a big reason to change (from their eyes). If you gear it high, how are you fundamentally different from a traction drive? High gearing implies traversing long distances. When you're doing that, a traction drive would certainly be able to go slightly diagonally to counteract losing strafing ability.[/quote] |
#11
If you really think the best teams in FIRST don't use a single minute of their 6 month long offseason to ever try a new idea, and that you are the enlightened one here, go ahead. I'd just rather we not endlessly debate in a humorous thread. |
#12
![]() Match 1 | Match 2 Last edited by NickE : 04-08-2011 at 22:41. |
#13
it all comes down to implementation. a well designed traction will stomp a poorly designed mecanum. I wish i had footage to back this up, but my team's bot this year was mecanum. we were the fastest bot that showed up to BMR. if our manipulator had worked better, we'd made eliminations (234 told us that had their alliance mate not disagreed, they would have picked us for a 3rd defense bot). it also had no problems during the season either other than a spare practice gearbox having a defective gear from the factory (one stolen from a 2009 KOP gearbox fixed it). whatever on this topic... people use what people use... |
#14
version 2 of the arm and minibot/launcher improved things in st. louis, but communication issues between myself and the head programmer led to code issues, the drivers didn't have enough practice with the final system, and a catastrophic failure ended it. it proves that although a good drivetrain is good, it isn't everything. Trust me, my years on 1747 taught me that equally well. In 2010, we could "glide" over bumps, push robots away from towers before they could hang, and some rowdy drivers of ours (not endorsing this) even disabled my current team's (2783) drivetrain in one match and flipped a rookie in another (anybody at buckeye regional that year knows about it). however, the kicker broke beyond repair, the vacuum didn't work, the roller to replace the vacuum was destroyed in the kicker failure, and the hanging device never worked. only this time, at boilermaker regional, we were picked by the 1st seed alliance (with 1501 and 1018) but lost in the semi finals in a close battle. by the way, it was a 2 speed traction drive (front traction, rear omni duals). |
