Re: pic: 1675's REAL IRI Upgrade
I had no idea 1318 was being defended in that match. They also moved very slowly and aimlessly - not exactly running circles, unless you mean the literal circular path they take?
I honestly don't see why this thread had to turn into an argument. The reason the picture exists is because of two friend teams joking about their disagreement on design choices. They're clearly able to be light hearted about this. Why not us? |
You certainly encouraged a non-light hearted debate early on in the thread.
Wow another mecanum debate!
I have always been skeptical about mecanums but I wasn't solely set against using them until last year 2010 driving at an off-season event and realized how easy it is to push those wheels around the field (robot I was driving was 4wd: two pnuematic, two omni). Ever since realizing how easy it was to push them, I have zero desire to use them* unless there is a game that separates alliances from contacting each other. I could never justify a decision that would leave our robot so helpless under defense. This year our team built a 6wd plaction robot with the mindset as rookies that we will build a robot that can simply play the game (low row + minibot that averaged a logo and a 1st place minibot at regional level. 12 for 12 deployments and 8 for 8 at STL). We knew we wouldn't be the best in most matches and designed our drivebase to be powerful on the field and pushed around many 6wd/8wd and some swerves too. Not matter how bad your upper assembly turns out, you should always design your drivebase to be one of the strongest on the field. I have heard a lot of "they can out maneuver" or "strafe around opponents" but whenever I hear that I just want to see someone do it (and bad/stationary defenders don't count). ![]() ***no octocanums were mentioned in this post*** Last edited by BrendanB : 05-08-2011 at 21:52. |
Fix your own robot's issues first, then maybe you'll have a valid enough stance on something to be allowed to preach to other people. (some of whom are mentors and also former world champion drivers) +.02, Agrees with Tom |
Show me the mentor who has never built a bad robot and I'll show you either a new mentor, a liar, or Andy Baker. One of the most important things one can do is learn from mistakes and this means that we have to make them. This means you can't discount someone's analysis merely based on the fact that they have screwed up in the past. |
The circles was a joke, the robot did do a lap around a defender. I think that 1318 was able to maneuver better than most of the other robots on the feild, and a large part of that was their drivers ability to use the strafing effectively to move through the congestion, while it obviously says nothing about robot performance at the highest level, mechanums in this case proved to work very well. |
#7
That's a little extreme. I mean, sure, we're not talking about the LOLz we got anymore; and, yes, there are already enough threads about Mecanum vs any other drive train, but the conversation has still been somewhat intelligent and hasn't degraded to people just yelling and blindly ignoring everyone else. Actually, this is one of the better threads I've read as far reasonably intelligent posts.
I didn't know that people actually knew that. 2 world championships, just to give him some more cred. |
#8
***removed***
#9
Definitely a funny picture! Hopefully everybody else who has read the mecanum vs 6WD threads enjoys it as much as I did.
I don’ t see too many people making huge generalizations in this thread, which is good. Here is what I will add: 1) Mecanum is in some ways easier to drive than 6WD. This is because it gives you room for error. If you miss your route to a scoring peg by a bit, you simply correct it in 1-2 seconds by strafing. You don’t need to learn ridiculously complicated drive maneuvers – just drive it like a tank and strafe when appropriate. I’m not advocating sloppy driving– I’m saying that it probably takes more practice time to be a really effective 6WD operator, because it takes longer to adjust if you miss. This is relevant for teams that don’t have a practice robot / practice field or highly experienced FRC drivers. Know of any teams like that? 2) Mecanum is approximately even with 6WD in a few categories that I have seen occasionally cited as advantages for 6WD: complexity, cost, and weight. As a basis for comparison, I’m using “kitbot on steroids” as the 6WD, compared to 6” mecanum drive direct driven with with Toughbox Nanos. The mecanum drive costs about $300 more – not a giant amount when you spend $5000+ on the kit. The weight is about the same, and it’s not really any more difficult to assemble and program than a basic 6WD. The code is provided to everyone. You can bolt a mecanum drive to the kit frame in a week and then focus on the rest of the robot, just as you can with 6WD. 3) This year we had a relatively narrow scoring zone to share with our alliance partners, and the other team was not allowed to drive into it. A mecanum robot can spend most of its time in that protected zone if somebody is feeding tubes, which partially eases the vulnerability to pushing defense. We looked at that situation and went with mecanum, thinking it would help us score faster in tight quarters. One can look back at that reasoning and argue that we made a poor tradeoff, but we did have sane reasoning to go by. It is going a bit too far to generalize to the effect that there can never be a valid reason to select a mecanum drive. 4) At the regional level, mecanum drives held up pretty well. Plenty of teams have brought home regional banners using a mecanum drive along with solid manipulators / driving / etc. There’s nothing wrong with that. _________________ Overall, I am more of a fan of 6WD after seeing how good the best of them looked on the field this year. I was surprised and impressed by how quickly and easily some of the 6WD drivers were able to hang tubes – essentially, their driving skill gave their 6WD robots the benefits we were looking for out of a mecanum drive. That was an eye opener. We are happy with our robot and our accomplishments from this year, but we’ve been playing with 6WD prototypes this summer and will probably bring some traction next year. |
#11
I remember whatching 1675 returning the favor by generously donating 50 or so mecanum rollers to 1625.
By the way, did you guys ever find all of those? |
#12
Im more curious as to where they got the colored tread
#13
Go to Mcmastercarr.com and search for inclined conveyor belting.
#14
Reported
