Go to Post Inspectors are your friends and are there to make sure you are safe and legal to compete. - Al Skierkiewicz [more]
Unread 08-08-2011, 21:43
davepowers's Avatar
davepowers davepowers is offline
Currently dreaming about robots
AKA: Danger Dave
FRC #1687 (Highlander Robotics)
davepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud ofdavepowers has much to be proud of
Re: GUS 228 Lunacy Robot Rebuild
Originally Posted by Duke461 View Post
Very cool! What's the purpose of the pneumatic on the intake roller mechanism?
Thank you! And the pneumatics on the intake are to direct the balls into the loading hopper of the robot. When the robot is intaking balls, the intake is pushed out and the middle roller wall is driven in reverse to pull the balls into the first chamber of the robot, then when we go to score, the intake is pulled into let the ball roll from the first hopper to the back shooter hopper where the middle roller wall is driven forwards to pull the balls up the to shooter at the top of the back of the robot! Hope that answered your question!
-Dave
David Powers - Deans List Finalist - WPI 17' - Bleed True Clothing
1999-xxxx FRC228, GUS Robotics Inc.
2013-xxxx FRC1678, Highlander Robotics
