Go to Post Remember to drive it like you stole it but be sure that it is in OVERDRIVE. - Steve W [more]
Unread 09-08-2011, 02:42
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Re: What is the difference between a 6 wheel swerve and a 4 wheel swerve?
I keep seeing this posted, but I don't understand how that is an advantage.
What is a 6wd doing that a swerve can't (aside from possibly climb easier, which wasn't the reason posted in the document...)?
If the wheels are not steered independently, (which I don't remember them being on 1625's 2010 robot) then it allows the robot to rotate about its center much easier, with far less turning scrub than a 4WD crab setup. It also gets you to Einstein and turns lots of heads and costs a small fortune to make.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
