Go to Post Adaptability is the key folks. Your job will not be the same 10 years from now (when I retire), or 20 years or 30 years from now. The tools and systems you use will change, and you must be able to adapt along with them. - Bill Moore [more]
Unread 11-08-2011, 16:29
ZipTie3182's Avatar
ZipTie3182 ZipTie3182 is offline
AKA: Anna Sklenar
FRC #3182 (Athena's Warriors)
ZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the roughZipTie3182 is a jewel in the rough
Durability of AM Plaction Wheels for Parades
Hi everyone,
We are designing a showbot that will be partially used in parades (but mostly expos) for CT First. I was wondering if anyone had an comments on how AM plaction wheels hold up after driving on pavement in a parade. And after how many hours/miles the treads would need to be replaced?
If you have found that the wheels wear really quickly does anyone have any recommendations on what wheels would be usable instead? We're trying to keep the appearance of the drive train to "look" like an FRC robot for demonstration purposes, but don't want to wheels to wear too quickly. We're planning on using 6 inchers.
Thanks so much,
Anna
Unread 11-08-2011, 16:33
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: Durability of AM Plaction Wheels for Parades
Try this.
http://www.chiefdelphi.com/media/photos/35768
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You'll wear those out rather quickly if turning at all. If you're only going straight, they might last. If you can make hubs to adapt them to your setup, I'd recommend Colson wheels for this use. In fact, this year, we chose Colson wheels for many reasons, but one of them being we didn't want to deal with changing wheels/treads ever, including parades in the post-season.
Unread 11-08-2011, 17:17
Chris is me's Avatar
AKA: Pinecone
I'd use AM Kit wheels. They're cheaper and since it's outside the FIRST season, you don't really need maximum traction.
Unread 11-08-2011, 17:41
Hawiian Cadder's Avatar
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Unless you swapped the tread to a softer rubber, they should be good. We changed out the andymark rough-top for some Older stuff we had laying around. I think that rough-top tread gets grippier and less durrable as it ages and the oils come out.
